Fuji FinePix S1 Black Camera Kit inc 8GB Class 10 SD Card and Case
Quicklinx: 9PV4WS00 Mfr#: P10NC12730A 8GBCASE
  • SDHC Memory Card
Brimming with technologies to improve picture taking and advance creativity, the S1 offers everything you could want from a bridge camera, including a powerful 50x image-stabilized optical zoom lens, wireless communication, Full HD movie function - all wrapped in a robust dust and water-resistant body.
  • Keep on shooting when others quit
    When the heavens open, most compacts and bridge cameras will find themselves quickly stowed in bags and pockets for protection, but the S1 is different. Thanks to its weather-resistant body. It can be used in wet weather or dusty conditions without the usual worries, and keep shooting while other photographers miss those all-important shots. The lens-body integrated design and sealing on approximately 70 areas are designed to allow field photography without typical worries about the weather, season or general shooting environment.
  • High quality, versatile lens design
    The S1 features Fujinon 50x optical zoom lens with a bright F2.8-F5.6 aperture range and 3.0-stop lens-shift image stabilization. The wide zoom range and additional super macro mode offers a huge array of shooting styles from wide angle scenic shots to tightly cropped telephoto framing. By effectively arranging the 2 aspherical and 4 ED lenses in a structure of 13 elements in 11 groups, high image quality is successfully achieved with reduced aberration, while superb sharpness is achieved from the center to the edges throughout the zoom range. Fujinon's unique multi-layer coating technology, super EBC, is applied to reduce ghosting and flare, and crisp, clear photos can be shot even under severe shooting conditions such as backlighting.
  • Improved movie recording
    The S1 offers high-precision, Full HD (1920 x 1080, 60p) movie recording and its newly developed 5-axis image stabilization and 3D noise reduction have greatly improved performance when shooting video. The optical and electronic 5-axis image stabilization reduces blurring from vertical, horizontal and rotational movement during video capture, which often occurs when walking, and further smoothness is applied by a side lever which can set the zoom speed in two levels. This side lever allows users to smoothly and freely operate the zoom with their left hand, while operating the shutter button with their right, and in its high-speed mode, the camera can quickly zoom in the subject.
  • Great features mean great pictures
    The FinePix S1 is no slouch when it comes to features with everything required by today's demanding photographers onboard and easy to use. Its electronic viewfinder has a 920k-dot resolution for better reproduction of the scene in strong sunlight and its large, clear vari-angle LCD means images can be composed more easily at low angles, such as when shooting flowers or high up when filming subjects over a crowd of people. To ensure sharp images when focusing manually, there's also a focus peak highlight function, which emphasizes the outline of the subject and any other areas with high contrast when they're brought into focus, and the S1 also shoots in RAW mode for more latitude in the development of pictures.
Fujifilm FinePix S1 - digital camera - Fujinon
Digital camera - compact
Lens Included
Fujinon
Memory Card Slot
SD card
Wireless Interface
Wi-Fi
Sensor Resolution
16.4 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 50x zoom - 4.3 - 215 mm - f/2.8-5.6
Focus Adjustment
Automatic, manual
Min Focus Distance
40 cm
Digital Zoom
2x
Image Stabiliser
Optical
Camera Flash
Pop-up flash
Viewfinder
Built-in - 0.2" - colour - electronic
Display
LCD display - 3"
Supported Battery
Fujifilm NP-85 Li-ion rechargeable battery (included)
HDMI, USB 2.0
13.31 cm x 11.03 cm x 9.09 cm
640 g
Lens Included
Fujinon
Enclosure Colour
Sensor Resolution
16.4 Megapixel
Optical Sensor Type
BSI-CMOS
Total Pixels
16,800,000 pixels
Effective Sensor Resolution
16,400,000 pixels
Optical Sensor Size
1/2.3"
ISO (Max)
12800
Optical Zoom
50x
Digital Zoom
2x
Image Stabiliser
Optical
Built-in Optical Image Stabiliser
Face Detection
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support
Auto Focus
TTL contrast detection
AE/AF Control
Subject-tracking AF
Digital Video Format
H.264, MOV
Image Recording Format
JPEG, RAW, RAW + JPEG
1920 x 1080
HDMI, USB 2.0, IEEE 802.11b/g/n
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 400, ISO 200, ISO 1600, ISO 3200, ISO auto, ISO auto (100-400), ISO auto (100-800), ISO auto (100-3200), ISO auto (100-1600), ISO 6400 (8MP), ISO 12800 (4MP)
Exposure Metering
Multi-segment, spot, average
Exposure Metering Zones
256
Exposure Modes
Programme, automatic, manual, aperture-priority, shutter-priority
Shooting Programs
Landscape, portrait mode, night mode, text, party/indoor, fireworks, flower, sports mode, sunset, beach, night (tripod), snow, natural light & with flash, zoom bracketing
Special Effects
Fisheye, soft focus, miniature, HDR, partial colour, Toy camera, High Key, Low Key, Pop Colour, Cross Screen, Dynamic tone
White Balance
Custom, automatic, presets
White Balance Presets
Fine, incandescent, shade, fluorescent light (cool white), fluorescent light (warm white), fluorescent light (daylight colour)
Max Shutter Speed
1/2000 sec
Min Shutter Speed
30 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
Auto Exposure Bracketing
3 steps in 1/3, 2/3 or 1 EV steps
Lens System
Fujinon zoom lens - 50x zoom - 4.3 - 215 mm - f/2.8-5.6
Focal Length Equivalent to 35mm Camera
24 - 1200mm
Focus Adjustment
Automatic, manual
Min Focus Distance
40 cm
Macro Focus Range
1cm
Zoom Adjustment
Motorised drive
Lens Construction
11 groups / 13 elements
Aspherical lens, XLD (Extra Low Dispersion) glass, Super EBC (Electron Beam Coating)
Camera Flash
Camera Flash
Pop-up flash
Flash Modes
Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
AF illuminator
Effective Flash Range
0.45 m - 8 m: ISO auto (wide lens) , 3.5 m - 4 m: ISO auto (tele lens) , 0.3 m - 3 m: ISO auto (macro lens)
Additional Features
Continuous Shooting Speed
3 frames per second, 5 frames per second, 10 frames per second
Self-Timer Delay
10 sec, 2sec
Flash Terminal
Hot shoe
Additional Features
RGB primary colour filter, digital image rotation, histogram display, cropping an image, resizing an image, Automatic Scene Recognition (SR Auto), interval shooting mode, Motion Panorama 360, HDR image enhancement technology, high-speed recording, date stamp, silent shooting
Viewfinder
Viewfinder Type
Built-in - electronic
Viewfinder Colour Support
Viewfinder Diagonal Size
0.2"
Viewfinder Resolution
920,000 pixels
Optical Viewfinder Field Coverage
97%
Auto eye sensor
Display
3" LCD display
Display Format
920,000 pixels
Display Form Factor
Built-in
Microphone
Microphone Operation Mode
Stereo
Microphone Features
Wind noise reduction
Connector Type
USB 2.0 , HDMI output
Lens cap, shoulder strap, AC power adaptor, USB cable, lens cap strap, shoe cap, power plug adapter
Protection
Weatherproof, dust-resistant
Battery Type
Fujifilm NP-85 Lithium Ion
Details
Battery Life Details
Photo shooting - 350 shots (AUTO mode)
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
Image Storage
JPEG 4608 x 3456 , JPEG 4608 x 3072 , JPEG 4608 x 2592 , JPEG 3456 x 3456 , JPEG 3264 x 2448 , JPEG 3264 x 2176 , JPEG 3264 x 1840 , JPEG 2432 x 2432 , JPEG 2304 x 1728 , JPEG 2304 x 1536 , JPEG 1920 x 1080 , JPEG 1728 x 1728
Video Capture
H.264 - 1920 x 1080 - 60 fps , H.264 - 1280 x 720 - 60 fps , H.264 - 640 x 480 - 30 fps , H.264 - 240 x 180 - 480 fps , H.264 - 320 x 240 - 240 fps , H.264 - 640 x 480 - 120 fps
13.31 cm
11.03 cm
9.09 cm
640 g
10 - 80% (non-condensing)
