Fuji FinePix L55 Digital Camera - Red
Quicklinx: 7Q9WWS00 Mfr#: P10NC06160A
  • SDHC Memory Card
The Fuji FinePix L55 is a fun point and shoot compact camera that features 12 megapixels, an impressive 2.4 inch LCD screen for sharing photos, a wide 38mm wide angle lens with 3x optical zoom allowing you to get close to distant subjects effortlessly. Fun fancy features include Motion Panorama, 17 Scene Modes, PictBridge compatibility, Smile shutter, Face detection and HD movie recording. With a high sensitivity of ISO 1600, digital anti-blur and Auto Scene Recognition, the Fuji FinePix L55 is a great little, low-light, intelligent performer making it the ideal partner for nights out with friends and family.
  • Great picture quality, compact design
    Inside the L55 you'll find a 3x optical zoom and 12-megapixels of resolution, providing you with amazing picture quality whatever the occasion.
  • Motion panorama and intelligent shooting modes
    Advanced shooting modes enable you to tackle any subject with ease. Why not use Fujifilm's advanced Motion Panorama technology to capture stunning landscape shots.
  • Take a different view with a 3x optical zoom
    Zoom from wide angle to telephoto with the flick of a switch, changing your viewpoint instantly. At the wide-angle end of the zoom range you'll be able to take in big group shots and landscapes. Telephoto settings will take you closer to the action, and are great for portraits.
  • 12-megapixel resolution
    Capture fine detail in images that are packed with color and tone. Reproduce pictures at large print sizes, or crop them on your computer without loosing quality.
  • High-sensitivity ISO1600
    When light levels get low the FinePix L55 lets you keep shooting, thanks to adjustable ISO sensitivity that extends as far as ISO1600. Raising the ISO sensitivity is also a great way to freeze fast moving action in good lighting conditions.
  • Digital image stabilization
    If the L55 predicts image blur due to camera movement, it shortens the shutter speed to compensate, prioritizing image sharpness.
Fujifilm FinePix L55 - digital camera - Fujinon
Digital camera - compact
Lens Included
Fujinon
Memory Card Slot
SD card
Sensor Resolution
12.0 Megapixel
Max Video Resolution
640 x 480
Lens System
Zoom lens - 3x zoom - 6.8 - 20.4 mm - f/3.9-5.9
Focus Adjustment
Automatic
Min Focus Distance
60 cm
Digital Zoom
6.3x
Image Stabiliser
Electronic
Camera Flash
Built-in flash
Display
LCD display - 2.4"
Supported Battery
Li-ion rechargeable battery - 720 mAh (included)
Composite video/audio, USB 2.0
Red
9.4 cm x 3.2 cm x 6 cm
100 g
Lens Included
Fujinon
Enclosure Colour
Red
Sensor Resolution
12.0 Megapixel
Optical Sensor Type
CCD
Effective Sensor Resolution
12,000,000 pixels
Optical Sensor Size
1/2.3"
ISO (Max)
1600
Optical Zoom
3x
Digital Zoom
6.3x
Image Stabiliser
Electronic
Face Detection
Services and Applications
YouTube capture mode
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support
Auto Focus
TTL contrast detection
Digital Video Format
AVI, MJPEG
Image Recording Format
JPEG
640 x 480
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 400, ISO 200, ISO 1600, ISO auto
Exposure Metering
Multi-segment
Exposure Metering Zones
256
Exposure Modes
Programme, automatic
Shooting Programs
Landscape, portrait mode, night mode, flower, sports mode, sunset, beach, night (tripod), natural light, snow, natural light & with flash, smile shot, motion panorama
White Balance
Automatic, presets
White Balance Presets
Fine, incandescent, shade, fluorescent light (cool white), fluorescent light (daylight), fluorescent light (warm white)
Max Shutter Speed
1/2000 sec
Min Shutter Speed
4 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
Lens System
Fujinon zoom lens - 3x zoom - 6.8 - 20.4 mm - f/3.9-5.9
Focal Length Equivalent to 35mm Camera
38 - 114mm
Focus Adjustment
Automatic
Min Focus Distance
60 cm
Macro Focus Range
10-100cm
Zoom Adjustment
Motorised drive
Lens Construction
5 groups / 5 elements
Built-in lens shield
Camera Flash
Camera Flash
Built-in flash
Flash Modes
Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
Effective Flash Range
0.3 m - 3.1 m
Additional Features
Continuous Shooting Speed
1.2 frames per second
Self-Timer Delay
10 sec, 2sec
Additional Features
RGB primary colour filter, digital image rotation, cropping an image, resizing an image, Automatic Scene Recognition (SR Auto), photo album function, face detection, Blink Detection technology, Smile Detection technology, automatic display brightness adjustment, Motion Panorama
Display
2.4" LCD display
Display Format
110,000 pixels
Display Form Factor
Built-in
Microphone
Microphone Operation Mode
Mono
Connector Type
USB 2.0 , Composite video/audio output
Software
Software
Drivers & Utilities
Hand strap, power adapter, USB cable
Battery Type
Fujifilm NP-45A Lithium Ion
Details
Battery Life Details
Photo shooting - 160 shots (AUTO mode)
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDHC Memory Card
Image Storage
JPEG 4000 x 3000 , JPEG 4000 x 2666 , JPEG 4000 x 2248 , JPEG 2816 x 2112 , JPEG 2048 x 1536
Video Capture
AVI - 640 x 480 - 30 fps , AVI - 320 x 240 - 30 fps
9.4 cm
3.2 cm
6 cm
100 g
10 - 80% (non-condensing)
