A high-quality Fujinon 3x zoom lens delivers picture-perfect results across the entire zoom range, from wide-angle compositions to dramatic close-up shots. An impressive 14-megapixel resolution won't miss the finest details of your subject. Images are captured sharp and clear, in vivid colors, even when printed at large sizes. The large, bright LCD display makes it easy to compose great photos. Sharing pictures is a pleasure, thanks to a high-impact 230,000-dot resolution.
Fujinon 3x optical zoom lens and a 14-megapixel sensor
A high-quality Fujinon 3x zoom lens delivers picture-perfect results across the entire zoom range, from wide-angle compositions to dramatic close-up shots. -
14-megapixel with vivid colors and clarity
An impressive 14-megapixel resolution won't miss the finest details of your subject. Images are captured sharp and clear, in vivid colors, even when printed at large sizes. -
HDTV-compatible photos and video
Able to capture both photos and movies in high-definition 16:9 format, the FinePix JV500 lets you discover the impact of full-screen HDTV image display. Capture high resolution images in 16:9 format (1280 x 720 pixels). -
Post capture editing
The in-camera movie and image editing functions let you artistically enliven photos, creating distinctive ambiances. -
6 scene SR auto
Framed scenes are automatically detected and selected into appropriate camera settings: portrait, landscape, night, macro, night portrait, and backlit portrait. -
Face detection
Face detection optimizes people pictures by detecting faces and adjusting focus and exposure to ensure bright, clear results. -
2.7-inch clear LCD
- Compact
- Resolution
- 14 Megapixel
- Optical Zoom
- 3
- Red
- Camera Flash / Type
- Built-in flash
- Red
- Dimensions & Weight / Depth
- 3.2 cm
- Dimensions & Weight / Height
- 5.98 cm
- Dimensions & Weight / Weight
- 100 g
- Dimensions & Weight / Width
- 9.6 cm
- Display / Diagonal Size
- 2.7 in
- Header / Product Line
- Fujifilm FinePix
- Lens System / Lens Aperture
- F/3.9-5.9
