Fuji FinePix F600EXR Digital Camera - White
Quicklinx: 7Q4MWS00 Mfr#: P10NC05990A
  • SDHC Memory Card
A go-anywhere do-anything compact camera that is the perfect travelling companion. A 15x zoom range takes you from seriously wide angle to up-close telephoto while a 16-megapixel EXR CMOS sensor captures every detail for superlative image quality.
Built-in GPS technology geotags images and movies clips with your location - great for re-living those travelling memories back home.
16-megapixel EXR-CMOS sensor
Capture every detail in images that are packed with colour depth. A high-resolution 16-megapixel EXR sensor that is versatile enough to cope in all conditions.
GPS geotagging
Know exactly where you were when you took every shot. The FinePix F600's integrated GPS technology tags your pictures with location information as you take them.
15x optical zoom
Equivalent to a 24-360mm zoom on a full-frame camera, a 15x optical zoom provides wide angles of view for landscapes and street photography, as well as telephoto settings for wildlife, sport and action.
Raw + JPEG shooting
Capture JPEG files for convenience or Raw files for the ultimate in picture quality and flexibility. Or why not shoot both at the same time for the best of both worlds?
Full-HD movies
Capture video footage at 1080p resolution, along with stereo sound, using the same camera you use for still photography. Use stills and video to tell a complete story.
99 scene mode patterns, and EXR AUTO
Let the FinePix F600 pick the correct camera settings for the job in hand by selecting an appropriate scene mode. EXR Auto technology analyses a subject and picks the appropriate sensor mode
Motion Panorama
Create impressive in-camera panoramic photographs simply by panning the F600EXR through the scene, covering angles up to 360°. No post processing or complicated editing required.
Image stabilisation
The F600 detects any vibrations and moves the sensor by tiny increments to counteract them. Perfect for long-lens shooting, or photography in low light where camera shake can spoil images.
  • Advanced scene recognition
    The pioneering EXR AUTO with a motion detection capability to virtually reduce subject blur in lighting conditions. Thanks to motion detection, available shooting types, come from recognized scenes and automatically optimized EXR modes, have expanded into 99 patterns in EXR AUTO mode.
  • Capture still night scenes with breathtaking quality
    At night when the EXR AUTO detects a still dark scene like a cityscape at sunset, it uses multi-image capture technology and dual IS to shoot the scene with amazing brightness, clarity and less noise than ever.
  • Shoot dynamic night shots with stunning results
    When motion detection detects a moving subject at night, the EXR AUTO does not use multi-image capture technology because it captures and merges moving subjects into a blurred image. Instead EXR AUTO optimizes sensitivity and image stabilization, and takes a single bright, sharp exposure.
  • Advanced anti blur
    When shooting dark scenes, Advanced anti blur adds the power of EXR CMOS and Multi Frame technology to combine 4 frames into a single, sharp blur image with remarkably low noise.
  • Super high quality Full HD movies
    Able to capture both photos and movies in high-definition 16:9 format, the FinePix F600EXR lets you discover the impact of full-screen HDTV image display.
  • Clear HD movies even in low lighting
    The FinePix F600EXR maximizes high sensitivity to capture exceptionally crisp and colorful full HD video (1080p; 30fps/high profile) with impressive stereo sound, even in low-light conditions. AF will instantly capture the object, even allow 15x zoom ups during your recordings.
  • Fujifilm's RP (Real Photo) technology
    The BSI (Back Side Illuminated) EXR CMOS sensor is a ground-breaking breakthrough in image quality. 16-megapixel is impressive and delivers a leap in resolution, but the real difference is in the technology.
  • EXr processor
    Harnessing the high-speed performance of the BSI EXR CMOS sensor, the dual CPU, EXR core and reconfigurable processor power a host of functions including high-sensitivity HD movies and continuous shooting as well as expanded scene recognition and pro modes while the vector graphics accelerator drives the enhanced image quality of the rich GUI.
Fujifilm FinePix F600EXR - digital camera - Fujinon
Digital camera - 1080p - compact
Lens Included
Fujinon
Memory Card Slot
SD card
Sensor Resolution
16.0 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 15x zoom - 4.4 - 66 mm - f/3.5-5.3
Focus Adjustment
Automatic, manual
Min Focus Distance
45 cm
Digital Zoom
3.4x
Image Stabiliser
Optical (image sensor shift mechanism)
Camera Flash
Pop-up flash
Display
LCD display - 3"
Supported Battery
Li-ion rechargeable battery (included)
Composite video/audio, HDMI, USB 2.0
White
10.4 cm x 3.3 cm x 6.3 cm
201 g
Lens Included
Fujinon
Enclosure Colour
White
Sensor Resolution
16.0 Megapixel
Optical Sensor Type
BSI EXR CMOS
Effective Sensor Resolution
16,000,000 pixels
Optical Sensor Size
1/2"
ISO (Max)
12800
Optical Zoom
15x
Digital Zoom
3.4x
Image Stabiliser
Built-in Optical Image Stabiliser
Face Detection
Navigation
GPS receiver
Services and Applications
YouTube capture mode
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support
Auto Focus
TTL contrast detection
AE/AF Control
Subject-tracking AF
Digital Video Format
H.264, MOV
Image Recording Format
JPEG, RAW, RAW + JPEG
1920 x 1080
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 400, ISO 200, ISO 1600, ISO 3200, ISO auto, ISO 6400 (8MP), ISO 12800 (4MP)
Exposure Metering
Multi-segment, spot, average
Exposure Metering Zones
256
Exposure Modes
Programme, automatic, manual, aperture-priority, shutter-priority
Shooting Programs
Landscape, portrait mode, night mode, text, party/indoor, fireworks, flower, Underwater, sports mode, sunset, beach, night (tripod), natural light, snow, natural light & with flash, EXR mode, portrait enhancer, dog, cat
Bracketing Modes
Dynamic Range Bracketing, Film Simulation Bracketing
White Balance
Custom, automatic, presets
White Balance Presets
Fine, incandescent, shade, fluorescent light (cool white), fluorescent light (daylight), fluorescent light (warm white), Underwater
Max Shutter Speed
1/2000 sec
Min Shutter Speed
8 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
Auto Exposure Bracketing
3 steps in 1/3, 2/3 or 1 EV steps
Lens System
Fujinon zoom lens - 15x zoom - 4.4 - 66 mm - f/3.5-5.3
Focal Length Equivalent to 35mm Camera
24 - 360mm
Focus Adjustment
Automatic, manual
Min Focus Distance
45 cm
Macro Focus Range
5-300cm
Zoom Adjustment
Motorised drive
Lens Construction
10 groups / 12 elements
Built-in lens shield
Camera Flash
Camera Flash
Pop-up flash
Flash Modes
Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
AF illuminator
Effective Flash Range
0.15 m - 3.2 m
Additional Features
Continuous Shooting Speed
8 frames per second, 3 frames per second, 5 frames per second, 11 frames per second
Self-Timer Delay
10 sec, 2sec
Additional Features
Audio recording, built-in speaker, RGB primary colour filter, digital image rotation, camera orientation detection, histogram display, in-camera red-eye removal, cropping an image, resizing an image, Automatic Scene Recognition (SR Auto), face detection, Motion Detection Technology, Face Recognition, Pet Recognition, Motion Panorama 360, EXR AUTO mode
Display
3" LCD display
Display Format
460,000 pixels
Display Form Factor
Built-in
Microphone
Microphone Operation Mode
Stereo
Connector Type
USB 2.0 , Composite video/audio output , HDMI output
Software
Software
Drivers & Utilities, MyFinePix Studio
Battery charger, hand strap, USB cable, audio / video cable
Battery Type
Fujifilm NP-50 Lithium Ion
Details
Memory / Storage
RAM Installed
33 MB
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Image Storage
JPEG 4608 x 3456 , JPEG 4608 x 3072 , JPEG 4608 x 2592 , JPEG 3264 x 2448 , JPEG 3264 x 2176 , JPEG 3264 x 1840 , JPEG 2304 x 1728 , JPEG 2304 x 1536 , JPEG 1920 x 1080
Video Capture
H.264 - 1920 x 1080 - 30 fps , H.264 - 1280 x 720 - 60 fps , H.264 - 640 x 480 - 30 fps
10.4 cm
3.3 cm
6.3 cm
201 g
