Your data requires the best possible protection, especially during mobile use. The Freecom Tough Drive 3.0 is a password protected mobile hard drive with a conveniently integrated USB 3.0 cable. Thanks to the internal suspension and shock-absorbing silicone enclosure, this mobile hard drive is resistant to sudden impact and shocks. The Tough Drive 3.0 is also available as high specified 7200 RPM drive (30% faster).
- Freecom ToughDrive - hard drive - 2 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 2 TB
- Form Factor
- 2.5"
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Spindle Speed
- 5400 rpm
- Shock resistant, water resistant, password authentication, dust-proof, fanless design
- Power Source
- USB bus
- Enclosure Colour
- Dark grey
- 14 cm x 8.3 cm x 1.9 cm
- 200 g
- 2-year warranty
- Capacity
- 2 TB
- Form Factor
- 2.5"
- Interface
- USB 3.0
- Internal Drive Interface
- Serial ATA
- 14 cm
- 8.3 cm
- 1.9 cm
- 200 g
Performance
- Interface Transfer Rate
- Spindle Speed
- 5400 rpm
Reliability
- MTBF
- 50,000 hours
Expansion & Connectivity
- 1 x USB 3.0 - 9 pin USB Type A
- Compatible Bay
- 2.5"
- Power Source
- USB bus
- Software Included
- Drivers & Utilities, NERO BackItUp
- OS Required
- Apple MacOS X 10.6 or later, Microsoft Windows Vista / XP / 7 / 8
- System Requirements Details
- Windows XP/7/8 - Pentium III - 900 MHz - RAM 256 MB , Windows Vista - Pentium III - 900 MHz - RAM 512 MB , MacOS X 10.6 or later - RAM 256 MB
- Cables Included
- 1 x USB 3.0 cable - integrated
- Enclosure Material
- Silicone
- FCC, IP54
- Enclosure Colour
- Dark grey
- Limited warranty - 2 years
- 10 °C
- 35 °C
