Freecom Mobile Drive Mg 1TB USB 3.0 & Thunderbolt 2.5" Portable Drive
Quicklinx: 8ZGZWS00 Mfr#: 56278
The Freecom Mobile Drive Mg, with Thunderbolt interface for lightning-fast data transfer speed, has been specifically designed as storage expansion for your MacBook. The enclosure of the Mobile Drive Mg is made from magnesium, a solid, lightweight, cool and environment-friendly material. Combined with the elegant and sleek design, the use of Magnesium has resulted in a perfect match for your MacBook. The Freecom Mobile Drive Mg is Mac HFS+ formatted and can be optimally used with your Mac from the moment you connect it to the USB port of your Mac or MacBook.
  • Versatile compatibility
    Designed to seamlessly integrate with both Mac and PC systems, the Freecom Mobile Drive Mg USB 3.0 & Thunderbolt ensures effortless connectivity and file sharing across platforms.
  • High-speed performance
    With interface speeds of up to 10 Gbps using Thunderbolt and 5.0 Gbps with USB 3.0, this external hard drive delivers rapid data transfer rates, making it ideal for quick file sharing and backups.
  • Portable and durable
    The Freecom Mobile Drive's compact, portable form factor and robust design, capable of withstanding up to 50,000 hours of use, make it the perfect companion for on-the-go data management without compromising on reliability.
Freecom Mobile Drive Mg USB 3.0 & Thunderbolt - hard drive - 1 TB - USB 3.0 / Thunderbolt
Hard drive - external (portable)
1 TB
2.5"
Data Transfer Rate
10 Gbps (Thunderbolt) / 5.0 Gbps (USB 3.0)
HFS+ formatted
Power Source
USB bus, Thunderbolt bus
Enclosure Colour
Silver
12.9 cm x 8.1 cm x 1.5 cm
175 g
1 TB
2.5"
HFS+ formatted
12.9 cm
8.1 cm
1.5 cm
175 g
Performance
Interface Transfer Rate
Reliability
MTBF
50,000 hours
Expansion & Connectivity
1 x USB 3.0 , 1 x Thunderbolt
Compatible Bay
2.5"
Power Source
Apple MacOS X 10.4 or later
1 x USB 3.0 cable - external , 1 x Thunderbolt cable - external
Enclosure Colour
Silver
10 °C
35 °C
