The Freecom Mobile Drive Mg, with Thunderbolt interface for lightning-fast data transfer speed, has been specifically designed as storage expansion for your MacBook. The enclosure of the Mobile Drive Mg is made from magnesium, a solid, lightweight, cool and environment-friendly material. Combined with the elegant and sleek design, the use of Magnesium has resulted in a perfect match for your MacBook. The Freecom Mobile Drive Mg is Mac HFS+ formatted and can be optimally used with your Mac from the moment you connect it to the USB port of your Mac or MacBook.
Versatile compatibility
Designed to seamlessly integrate with both Mac and PC systems, the Freecom Mobile Drive Mg USB 3.0 & Thunderbolt ensures effortless connectivity and file sharing across platforms. -
High-speed performance
With interface speeds of up to 10 Gbps using Thunderbolt and 5.0 Gbps with USB 3.0, this external hard drive delivers rapid data transfer rates, making it ideal for quick file sharing and backups. -
Portable and durable
The Freecom Mobile Drive's compact, portable form factor and robust design, capable of withstanding up to 50,000 hours of use, make it the perfect companion for on-the-go data management without compromising on reliability.
- Freecom Mobile Drive Mg USB 3.0 & Thunderbolt - hard drive - 1 TB - USB 3.0 / Thunderbolt
- Hard drive - external (portable)
- Capacity
- 1 TB
- Form Factor
- 2.5"
- Interface
- Data Transfer Rate
- 10 Gbps (Thunderbolt) / 5.0 Gbps (USB 3.0)
- HFS+ formatted
- Power Source
- USB bus, Thunderbolt bus
- Enclosure Colour
- Silver
- 12.9 cm x 8.1 cm x 1.5 cm
- 175 g
- 2-year warranty
- Capacity
- 1 TB
- Form Factor
- 2.5"
- Interface
- HFS+ formatted
- 12.9 cm
- 8.1 cm
- 1.5 cm
- 175 g
Performance
- Interface Transfer Rate
Reliability
- MTBF
- 50,000 hours
Expansion & Connectivity
- 1 x USB 3.0 , 1 x Thunderbolt
- Compatible Bay
- 2.5"
- Power Source
- OS Required
- Apple MacOS X 10.4 or later
- Cables Included
- 1 x USB 3.0 cable - external , 1 x Thunderbolt cable - external
- Enclosure Colour
- Silver
- Limited warranty - 2 years
- 10 °C
- 35 °C
