Freecom Mobile Drive Mg 1TB USB 3.0 & Thunderbolt 2.5" Portable Drive
Quicklinx: 8ZGZWS00 Mfr#: 56278
The Freecom Mobile Drive Mg, with Thunderbolt interface for lightning-fast data transfer speed, has been specifically designed as storage expansion for your MacBook. The enclosure of the Mobile Drive Mg is made from magnesium, a solid, lightweight, cool and environment-friendly material. Combined with the elegant and sleek design, the use of Magnesium has resulted in a perfect match for your MacBook. The Freecom Mobile Drive Mg is Mac HFS+ formatted and can be optimally used with your Mac from the moment you connect it to the USB port of your Mac or MacBook.
Freecom Mobile Drive Mg USB 3.0 & Thunderbolt - hard drive - 1 TB - USB 3.0 / Thunderbolt
Hard drive - external (portable)
1 TB
2.5"
Data Transfer Rate
10 Gbps (Thunderbolt) / 5.0 Gbps (USB 3.0)
HFS+ formatted
Power Source
USB bus, Thunderbolt bus
Enclosure Colour
Silver
12.9 cm x 8.1 cm x 1.5 cm
175 g
1 TB
2.5"
HFS+ formatted
12.9 cm
8.1 cm
1.5 cm
175 g
Performance
Interface Transfer Rate
Reliability
MTBF
50,000 hours
Expansion & Connectivity
1 x USB 3.0 , 1 x Thunderbolt
Compatible Bay
2.5"
Power Source
Apple MacOS X 10.4 or later
1 x USB 3.0 cable - external , 1 x Thunderbolt cable - external
Enclosure Colour
Silver
10 °C
35 °C
