Freecom Mobile Drive Classic II 320GB USB2 2.5" Hard Drive (Black)
Quicklinx: 6JSNWS00 Mfr#: 33576
Freecom Mobile Classic II 320GB Hard Drive
Compact storage on the go!
Whether you are a professional or home user, these days it is essential to be able to carry your valuable data anywhere with you. Ultra compact, easy-to-use and secure, this USB 2.0 powered portable hard drive makes transporting and sharing data easier than ever. Simply plug it into any computer's USB port and take your spreadsheets, documents, movies, photos or music anywhere you go. The perfect travel companion!
Key Features
  • Fast, low noise external mobile USB 2.0 hard drive
  • Ultra-compact size, ideal for use with a netbook or a notebook
  • USB powered, no power adapter needed
  • Excellent value for money
  • Turbo USB 2.0 driver for even faster data transfer speed (for Windows)
Don't want annoying noises while working? No problem, The Freecom Mobile Drive Classic II has no cooling fan, which ensures quiet operation at all times !
Need a hard drive but want to be trendy as well? The Freecom Mobile Drive Classic II has a stylish black design. It will look perfect next to your netbook or notebook !
For your convenience, the Freecom Mobile Drive has been partitioned (1 partition) and pre-formatted (FAT32 file system). The FAT32 format ensures maximum interchangeability of the Freecom Mobile Drive between different computers. Should you choose to format the Freecom Mobile Drive in another file system (e.g. NTFS), please be aware of possible problems when connecting the Freecom Mobile Drive to another computer than the one you used for formatting.
  • Home use
    Store all your digital photos, music, movies, games on one central location. Take the Freecom Mobile Drive Classic with you and share your files with friends. Make a backup of all your important documents and files.
  • Office use
    Store all your spreadsheets, documents, presentations on one central location. Take the drive home or on the road and work on your files away from the office. Make an extra backup of your valuable work files. Share data between computers and networks. Use the Freecom Mobile Drive Classic for software installations on multiple PCs.
Freecom Mobile Drive Classic II - hard drive - 320 GB - USB 2.0
Hard drive - external (portable)
320 GB
2.5"
USB 2.0
Data Transfer Rate
480 Mbps
Power Source
USB bus
Enclosure Colour
Piano black
11.5 cm x 7.6 cm x 1.2 cm
140 g
1-year warranty
320 GB
2.5"
USB 2.0
11.5 cm
7.6 cm
1.2 cm
140 g
Performance
Interface Transfer Rate
480 Mbps
Reliability
MTBF
50,000 hours
Expansion & Connectivity
1 x USB 2.0
Compatible Bay
2.5"
Power Source
USB bus
Microsoft Windows XP SP2, Microsoft Windows Vista, Apple MacOS X 10.4.8 or later
System Requirements Details
Windows XP/Vista - 1.6 GHz - RAM 512 MB , MacOS X 10.4.8 or later - RAM 512 MB
1 x USB cable - external
FCC
Enclosure Colour
Piano black
Limited warranty - 1 year
10 °C
35 °C
Resources
The following resources are available for the Freecom Mobile Drive Classic II 320GB USB2 2.5" Hard Drive (Black)
