Freecom Mobile Classic II 320GB Hard Drive
Compact storage on the go!
Whether you are a professional or home user, these days it is essential to be able to carry your valuable data anywhere with you. Ultra compact, easy-to-use and secure, this USB 2.0 powered portable hard drive makes transporting and sharing data easier than ever. Simply plug it into any computer's USB port and take your spreadsheets, documents, movies, photos or music anywhere you go. The perfect travel companion!
Key Features
- Fast, low noise external mobile USB 2.0 hard drive
- Ultra-compact size, ideal for use with a netbook or a notebook
- USB powered, no power adapter needed
- Excellent value for money
- Turbo USB 2.0 driver for even faster data transfer speed (for Windows)
Don't want annoying noises while working? No problem, The Freecom Mobile Drive Classic II has no cooling fan, which ensures quiet operation at all times !
Need a hard drive but want to be trendy as well? The Freecom Mobile Drive Classic II has a stylish black design. It will look perfect next to your netbook or notebook !
For your convenience, the Freecom Mobile Drive has been partitioned (1 partition) and pre-formatted (FAT32 file system). The FAT32 format ensures maximum interchangeability of the Freecom Mobile Drive between different computers. Should you choose to format the Freecom Mobile Drive in another file system (e.g. NTFS), please be aware of possible problems when connecting the Freecom Mobile Drive to another computer than the one you used for formatting.
Home use
Store all your digital photos, music, movies, games on one central location. Take the Freecom Mobile Drive Classic with you and share your files with friends. Make a backup of all your important documents and files. -
Office use
Store all your spreadsheets, documents, presentations on one central location. Take the drive home or on the road and work on your files away from the office. Make an extra backup of your valuable work files. Share data between computers and networks. Use the Freecom Mobile Drive Classic for software installations on multiple PCs.
- Freecom Mobile Drive Classic II - hard drive - 320 GB - USB 2.0
- Hard drive - external (portable)
- Capacity
- 320 GB
- Form Factor
- 2.5"
- Interface
- USB 2.0
- Data Transfer Rate
- 480 Mbps
- Power Source
- USB bus
- Enclosure Colour
- Piano black
- 11.5 cm x 7.6 cm x 1.2 cm
- 140 g
- 1-year warranty
- Capacity
- 320 GB
- Form Factor
- 2.5"
- Interface
- USB 2.0
- 11.5 cm
- 7.6 cm
- 1.2 cm
- 140 g
Performance
- Interface Transfer Rate
- 480 Mbps
Reliability
- MTBF
- 50,000 hours
Expansion & Connectivity
- 1 x USB 2.0
- Compatible Bay
- 2.5"
- Power Source
- USB bus
- OS Required
- Microsoft Windows XP SP2, Microsoft Windows Vista, Apple MacOS X 10.4.8 or later
- System Requirements Details
- Windows XP/Vista - 1.6 GHz - RAM 512 MB , MacOS X 10.4.8 or later - RAM 512 MB
- Cables Included
- 1 x USB cable - external
- FCC
- Enclosure Colour
- Piano black
- Limited warranty - 1 year
- 10 °C
- 35 °C
