Freecom Hard Drive Quattro 2TB USB 2.0 / FireWire/ eSATA Silver
Quicklinx: 64ZZWS00 Mfr#: 32226
Need a reliable and fast external hard drive? The Freecom Hard Drive Quattro has it all, thanks to the eSATA and FireWire 800 interfaces, making this drive ideal for people who work with large files such as DTP/graphical files and uncompressed video and audio. For optimal flexibility the drive is also equipped with FireWire 400 and USB 2.0 interfaces. 4 interfaces in one device! The Hard Drive Quattro comes in a stylish, heat absorbing aluminum enclosure which will complement the design of your PC or Mac. Quality, reliability, stylish, and with all common computer interfaces in one device - it does not get any more convenient than this!
Freecom Hard Drive Quattro - hard drive - 2 TB - FireWire 800 / FireWire / USB 2.0 / eSATA-300
Hard drive - external (desktop)
2 TB
Encryption Algorithm
128-bit AES
3.5"
Data Transfer Rate
800Mbps(FireWire800)/400Mbps(FireWire)/480Mbps(Hi-Sp.USB)/3Gbps(eSATA)
128-bit AES
Power Source
Included AC adapter
Enclosure Colour
Silver
15.5 cm x 14.8 cm x 4.3 cm
1.4 kg
2 TB
128-bit AES
3.5"
Internal Drive Interface
Serial ATA
128-bit AES
15.5 cm
14.8 cm
4.3 cm
1.4 kg
Performance
Interface Transfer Rate
Max Data Transfer Rate
300 MB/s
Reliability
MTBF
50,000 hours
Expansion & Connectivity
1 x USB 2.0 - 4 pin USB Type B , 1 x FireWire - 6 PIN FireWire , 2 x FireWire 800 - 9 pin FireWire 800 , 1 x eSATA - 7 pin external Serial ATA
Compatible Bay
3.5"
Power Source
Included AC adapter
Power adapter
Software Included
Drivers & Utilities
Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP
System Requirements Details
Windows XP - Pentium III - 900 MHz - RAM 256 MB , Windows Vista - Pentium III - 900 MHz - RAM 512 MB , MacOS X 10.4 - PowerPC G3
1 x USB cable - external , 1 x IEEE 1394 cable - external , 1 x IEEE 1394b cable - external , 1 x eSATA cable - external
FCC
Enclosure Colour
Silver
10 °C
35 °C
