Need a reliable and fast external hard drive? The Freecom Hard Drive Quattro has it all, thanks to the eSATA and FireWire 800 interfaces, making this drive ideal for people who work with large files such as DTP/graphical files and uncompressed video and audio. For optimal flexibility the drive is also equipped with FireWire 400 and USB 2.0 interfaces. 4 interfaces in one device! The Hard Drive Quattro comes in a stylish, heat absorbing aluminum enclosure which will complement the design of your PC or Mac. Quality, reliability, stylish, and with all common computer interfaces in one device - it does not get any more convenient than this!
- Freecom Hard Drive Quattro - hard drive - 2 TB - FireWire 800 / FireWire / USB 2.0 / eSATA-300
- Hard drive - external (desktop)
- Capacity
- 2 TB
- Encryption Algorithm
- 128-bit AES
- Form Factor
- 3.5"
- Interface
- Data Transfer Rate
- 800Mbps(FireWire800)/400Mbps(FireWire)/480Mbps(Hi-Sp.USB)/3Gbps(eSATA)
- 128-bit AES
- Power Source
- Included AC adapter
- Enclosure Colour
- Silver
- 15.5 cm x 14.8 cm x 4.3 cm
- 1.4 kg
- 2-year warranty
- Capacity
- 2 TB
- 128-bit AES
- Form Factor
- 3.5"
- Interface
- Internal Drive Interface
- Serial ATA
- 128-bit AES
- 15.5 cm
- 14.8 cm
- 4.3 cm
- 1.4 kg
Performance
- Interface Transfer Rate
- Max Data Transfer Rate
- 300 MB/s
Reliability
- MTBF
- 50,000 hours
Expansion & Connectivity
- 1 x USB 2.0 - 4 pin USB Type B , 1 x FireWire - 6 PIN FireWire , 2 x FireWire 800 - 9 pin FireWire 800 , 1 x eSATA - 7 pin external Serial ATA
- Compatible Bay
- 3.5"
- Power Source
- Power Device
- Power adapter
- Software Included
- Drivers & Utilities
- OS Required
- Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP
- System Requirements Details
- Windows XP - Pentium III - 900 MHz - RAM 256 MB , Windows Vista - Pentium III - 900 MHz - RAM 512 MB , MacOS X 10.4 - PowerPC G3
- Cables Included
- 1 x USB cable - external , 1 x IEEE 1394 cable - external , 1 x IEEE 1394b cable - external , 1 x eSATA cable - external
- FCC
- Enclosure Colour
- Silver
- Limited warranty - 2 years
- 10 °C
- 35 °C
