The Freecom Hard Drive Dock Quattro provides even more flexibility. Connect any 2.5" and 3.5" SATA hard drive in the dock and connect it to your PC or Mac via USB 2.0, FireWire 800, FireWire 400 or eSATA. It is ideal for temporary use of your internal hard drive, just in case you need to retrieve some files quickly.
- Freecom Hard Drive Dock Quattro - HDD docking station - SATA 3Gb/s - eSATA, FireWire 800, USB 2.0
- HDD docking station - external
- Bays
- 1
- Bus Type
- Expansion Bays
- 1 x hot-swap - 2.5" / 3.5" shared
- Hard Drive Form Factor Compatibility
- 2.5", 3.5"
- Interface
- SATA 3Gb/s
- Data Transfer Rate
- 3 Gbit/s
- Supported Devices
- Hard drive
- Bays
- 1
- 2.5", 3.5"
- Host Bus
Storage Controller
- Interface
- SATA 3Gb/s
- 3 Gbit/s
- Supported Devices
- Hard drive
- Bays
- 1 x SATA 3Gb/s - SATA
- Connections
- 1 x USB 2.0 - 4 pin USB Type A , 1 storage - eSATA-300 - 7 pin external Serial ATA , 1 x FireWire - 6 PIN FireWire , 1 x FireWire 800 - 9 pin FireWire 800
