Freecom Desktop Hard Drive XS 1.5TB USB 2.0 Black
Quicklinx: 64ZVWS00 Mfr#: 32232
The Freecom Hard Drive XS - world's smallest 3.5" external hard drive - is the ideal hard drive for cost-conscious users who do not want to compromise on quality and performance. Store your videos, photos, music, documents and other data on this extremely quiet hard drive and have your data always ready at hand. Thanks to its compact measurements the drive does not take up much space on your desk. The rubber enclosure provides the drive with optimal grip and reduces vibration.
Stylish and cost-eff ective external hard drive solution
Today's world is all about Gigabytes. Programs and data take up more and more storage space. The need for installing an extra hard drive on your PC or Mac is more present than ever. Opening your computer case and installing an internal hard drive can be a diffi cult job. So why not take the easy route? Freecom off ers you the perfect storage upgrade for your computer: the new Freecom Hard Drive XS, a compact, no-nonsense external 3.5" hard drive. No need to open your computer; just plug the Hard Drive into the USB (2.0 or 1.1) port of your PC or MAC and you instantly have a substantial increase in storage space. The Freecom Hard Drive XS is preformatted so you're ready to use your drive seconds after connecting it to your computer. At Freecom we create storage solutions from a consumer's perspective, where convenience, design and quality are key factors. Free your mind!
External USB 2.0 Hard Drive
  • World's smallest 3.5"external hard drive!
  • Quiet drive thanks to fanless design
  • Rubberized enclosure, reducing vibration and providing optimal grip
  • Turbo USB 2.0 driver for faster data transfer speeds (Windows only)
  • The easiest way to add extra storage capacity to your computer
  • Hot swappable, no need to turn off your computer
  • No device ID's or terminations to worry about
  • High quality, sleek design, only 18.2 x 11,4 x 3.1 cm, takes up less space on your desk
  • One year manufacturers warranty, free helpdesk support
Ideal for home and office use
Home use
  • Store all your digital photo's, music, movies, games
  • Take the Freecom Hard Drive XS with you and share your fi les with friends
  • Make an extra backup of all your important documents and fi les
Office use
  • Store all your spreadsheets, documents, presentations on one central location
  • Take the drive home or on the road and work on your fi les away from the offi ce
  • Make an extra backup of your valuable work fi les
  • Share data between computers and networks
  • Use the Freecom Hard Drive XS for software installations on multiple PC's
Freecom Hard Drive XS - hard drive - 1.5 TB - USB 2.0
Hard drive - external (desktop)
1.5 TB
3.5"
USB 2.0
Data Transfer Rate
480 Mbps
Power Source
Included AC adapter
Enclosure Colour
18.2 cm x 11.4 cm x 3.1 cm
0.86 kg
1-year warranty
1.5 TB
3.5"
USB 2.0
18.2 cm
11.4 cm
3.1 cm
0.86 kg
Performance
Interface Transfer Rate
480 Mbps
Expansion & Connectivity
1 x USB 2.0
Compatible Bay
3.5"
Power Source
Included AC adapter
Power adapter
Apple MacOS X 10.3 or later, Microsoft Windows Vista / 2000 / XP
1 x USB cable - external
Enclosure Colour
Limited warranty - 1 year
10 °C
35 °C
Resources
The following resources are available for the Freecom Desktop Hard Drive XS 1.5TB USB 2.0 Black
