Freecom 500GB ToughDrive USB 3.0 2.5" Portable Hard Drive
PRICE DROP!
Last Few Remaining
Price Drop
Quicklinx: 80GBWS00 Mfr#: 56058
Form Factor: 2.5"
Capacity: 500GB
Interface: SuperSpeed USB
Stock Status: Clearance
12 left in stock
£54.12 ex VAT
£64.94 inc VAT
Freecom ToughDrive 2.5inch Portable Hard Drive with USB 2.0 Connection, integrated USB Cable & Silicone Protective Cover
In today's world mobility has become a key factor. People who are on the road carry their whole office with them. Notebook, mobile phone, PDA, external hard drive... Imagine what can happen when you're late for a flight, running to the gate, and your external hard drive accidentally falls from your notebook case or out of your jacket pocket onto the floor... it breaks. Hundreds of hours of work, gigabytes of spreadsheets, documents, photo's... all gone. Not anymore! Freecom introduces the ToughDrive. The ideal external storage solution for people on the move.
Fitted with an internal anti-shock frame and a unique soft silicone cover, it can withstand bumps and drops so your drive is still fully functional after it has dropped. The ToughDrive ensures you can still access your valuable files. A safe feeling. Provided by Freecom.
Key Features
  • Durable, soft silicone cover, ideal for mobile computing
  • Internal anti-shock mechanism insulating the hard drive from shock
  • USB 3.0 for super fast data transfer - also connects to USB 2.0
  • Integrated USB cable, no extra connection cables needed!
  • Power via USB port, no power adapter needed
Freecom ToughDrive USB 3.0 - hard drive - 500 GB - USB 3.0
Hard drive - external (portable) - shock resistant, password authentication
500 GB
2.5"
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Shock resistant, password authentication
Power Source
USB bus
Enclosure Colour
Grey
14 cm x 8.3 cm x 1.9 cm
200 g
500 GB
2.5"
USB 3.0
Internal Drive Interface
Serial ATA
14 cm
8.3 cm
1.9 cm
200 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0
Compatible Bay
2.5"
Power Source
USB bus
Microsoft Windows Vista / XP / 7, Apple MacOS X 10.4.8 or later
System Requirements Details
Windows XP - Pentium III - 900 MHz - RAM 256 MB , MacOS X 10.4.8 or later - PowerPC G3 RAM 256 MB , Windows 7 - Pentium III - 900 MHz - RAM 256 MB , Windows Vista - Pentium III - 900 MHz - RAM 512 MB
1 x USB cable - integrated
Enclosure Colour
Grey
10 °C
35 °C
Form Factor: 2.5"
Capacity: 500GB
Brand: Freecom
Price Range Ex VAT: 50 - 100
