Freecom ToughDrive 2.5inch Portable Hard Drive with USB 2.0 Connection, integrated USB Cable & Silicone Protective Cover
In today's world mobility has become a key factor. People who are on the road carry their whole office with them. Notebook, mobile phone, PDA, external hard drive... Imagine what can happen when you're late for a flight, running to the gate, and your external hard drive accidentally falls from your notebook case or out of your jacket pocket onto the floor... it breaks. Hundreds of hours of work, gigabytes of spreadsheets, documents, photo's... all gone. Not anymore! Freecom introduces the ToughDrive. The ideal external storage solution for people on the move.
Fitted with an internal anti-shock frame and a unique soft silicone cover, it can withstand bumps and drops so your drive is still fully functional after it has dropped. The ToughDrive ensures you can still access your valuable files. A safe feeling. Provided by Freecom.
Key Features
- Durable, soft silicone cover, ideal for mobile computing
 - Internal anti-shock mechanism insulating the hard drive from shock
 - USB 3.0 for super fast data transfer - also connects to USB 2.0
 - Integrated USB cable, no extra connection cables needed!
 - Power via USB port, no power adapter needed
Robust design
The Freecom ToughDrive USB 3.0 is built to withstand the rigors of daily use, featuring a shock-resistant exterior that protects your data from accidental drops and bumps. Its integrated USB cable ensures you're always ready to connect and transfer files without the hassle of carrying extra accessories. -
High-speed connectivity
With an interface speed of 5.0 Gbps, courtesy of the SuperSpeed USB 3.0, this external hard drive offers rapid file transfers and backups, making it a suitable solution for busy professionals and multimedia enthusiasts who require efficiency and speed. -
Seamless compatibility
Designed to work effortlessly with both Mac and PC, the Freecom ToughDrive USB 3.0 eliminates the need for reformatting, offering a Plug-and-Play experience that ensures your files are accessible across different platforms without any extra steps.
 - Freecom ToughDrive USB 3.0 - hard drive - 500 GB - USB 3.0
 - Hard drive - external (portable)
- Capacity
 - 500 GB
- Form Factor
 - 2.5"
- Interface
 - USB 3.0
- Data Transfer Rate
 - 5.0 Gbps (USB 3.0)
 - Shock resistant, password authentication
- Power Source
 - USB bus
- Enclosure Colour
 - Grey
 - 14 cm x 8.3 cm x 1.9 cm
 - 200 g
 - 2-year warranty
- Capacity
 - 500 GB
- Form Factor
 - 2.5"
- Interface
 - USB 3.0
- Internal Drive Interface
 - Serial ATA
 - 14 cm
 - 8.3 cm
 - 1.9 cm
 - 200 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
 - 1 x USB 3.0
- Compatible Bay
 - 2.5"
- Power Source
 - USB bus
- OS Required
 - Microsoft Windows Vista / XP / 7, Apple MacOS X 10.4.8 or later
- System Requirements Details
 - Windows XP - Pentium III - 900 MHz - RAM 256 MB , MacOS X 10.4.8 or later - PowerPC G3 RAM 256 MB , Windows 7 - Pentium III - 900 MHz - RAM 256 MB , Windows Vista - Pentium III - 900 MHz - RAM 512 MB
- Cables Included
 - 1 x USB cable - integrated
- Enclosure Colour
 - Grey
 - Limited warranty - 2 years
 - 10 °C
 - 35 °C
