Freecom 2TB Mobile Drive XXS USB 3.0 2.5" Portable Hard Drive
Quicklinx: 9MWTWS00 Mfr#: 56334
Looking for the high possible capacity in the smallest possible size? Meet the smallest mobile drive in the world! The Mobile Drive XXS is the perfect solution for you.
Freecom's Mobile Drive XXS is the ideal mobile hard drive if you travel frequently. Or when you just need to have your files nearby at all times. Store them on your XXS and always have your business and personal files with you.
The Mobile Drive XXS is made out of rubber which not only provides a stylish look, but also gives the necessary grip to avoid dropping your hard drive.
  • Size matters
  • Your important files always at hand
  • Get a grip
Freecom Mobile Drive XXS 3.0 - hard drive - 2 TB - USB 3.0
Hard drive - external (portable)
2 TB
2.5"
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Power Source
USB bus
Enclosure Colour
12 cm x 8 cm x 1.6 cm
185 g
2 TB
2.5"
USB 3.0
12 cm
8 cm
1.6 cm
185 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Reliability
MTBF
50,000 hours
Expansion & Connectivity
1 x USB 3.0
Compatible Bay
2.5"
Power Source
USB bus
Apple MacOS X 10.6 or later, Microsoft Windows Vista / XP / 7 / 8
1 x USB cable - external
Enclosure Colour
10 °C
35 °C
