Freecom 1TB ToughDrive USB 3.0 2.5" Portable Hard Drive
Quicklinx: 86L2WS00 Mfr#: 56057
Form Factor: 2.5
Capacity: 1TB
Interface: SuperSpeed USB
10 left in stock
£67.87 ex VAT
£81.44 inc VAT
Your data requires the best possible protection, especially during mobile use. The Freecom ToughDrive is a specially protected mobile hard drive. Thanks to the internal suspension and shock-absorbing silicone enclosure, this mobile hard drive is resistant to sudden impact and shocks, and even withstands falls.
  • Robust design
    The Freecom ToughDrive USB 3.0 is built to withstand daily use, featuring a shock-resistant exterior that protects your data from accidental drops and bumps. Its integrated USB cable ensures you're always ready to connect and go, without the hassle of carrying extra accessories.
  • High-speed connectivity
    With an interface speed of 5.0 Gbps, thanks to the SuperSpeed USB 3.0, this external hard drive offers rapid file transfers and backups. This means less time waiting and more time getting work done, whether you're at the office or on-the-go.
  • Secure data protection
    The Freecom ToughDrive comes equipped with password authentication, offering an extra layer of security for your sensitive information. This feature ensures that your data remains safe and accessible only to authorized users.
Freecom ToughDrive USB 3.0 - hard drive - 1 TB - USB 3.0
Hard drive - external (portable)
1 TB
2.5"
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Shock resistant, password authentication
Power Source
USB bus
Enclosure Colour
Grey
14 cm x 8.3 cm x 1.9 cm
200 g
1 TB
2.5"
USB 3.0
Internal Drive Interface
Serial ATA
14 cm
8.3 cm
1.9 cm
200 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0
Compatible Bay
2.5"
Power Source
USB bus
Software Included
Nero BackItUp & Burn
Microsoft Windows Vista / XP / 7, Apple MacOS X 10.4.8 or later
System Requirements Details
Windows XP - Pentium III - 900 MHz - RAM 256 MB , MacOS X 10.4.8 or later - PowerPC G3 RAM 256 MB , Windows 7 - Pentium III - 900 MHz - RAM 256 MB , Windows Vista - Pentium III - 900 MHz - RAM 512 MB
1 x USB cable - integrated
Enclosure Colour
Grey
10 °C
35 °C
Form Factor: 2.5
Capacity: 1TB
Brand: Freecom
Stock Status: While stocks last
Stock Status: Clearance
