Freecom 1TB ToughDrive USB 3.0 2.5" Portable Hard Drive
Quicklinx: 86L2WS00 Mfr#: 56057
Your data requires the best possible protection, especially during mobile use. The Freecom ToughDrive is a specially protected mobile hard drive. Thanks to the internal suspension and shock-absorbing silicone enclosure, this mobile hard drive is resistant to sudden impact and shocks, and even withstands falls.
Freecom ToughDrive USB 3.0 - hard drive - 1 TB - USB 3.0
Hard drive - external (portable)
1 TB
2.5"
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Shock resistant, password authentication
Power Source
USB bus
Enclosure Colour
Grey
14 cm x 8.3 cm x 1.9 cm
200 g
1 TB
2.5"
USB 3.0
Internal Drive Interface
Serial ATA
14 cm
8.3 cm
1.9 cm
200 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0
Compatible Bay
2.5"
Power Source
USB bus
Software Included
Nero BackItUp & Burn
Microsoft Windows Vista / XP / 7, Apple MacOS X 10.4.8 or later
System Requirements Details
Windows XP - Pentium III - 900 MHz - RAM 256 MB , MacOS X 10.4.8 or later - PowerPC G3 RAM 256 MB , Windows 7 - Pentium III - 900 MHz - RAM 256 MB , Windows Vista - Pentium III - 900 MHz - RAM 512 MB
1 x USB cable - integrated
Enclosure Colour
Grey
10 °C
35 °C
