The Node 304 is the latest compact computer chassis from Fractal Design featuring a unique modular interior for outstanding configurability. The Node 304 accommodates up to six hard drives. Unused mounting brackets can removed to allow for long graphic cards, additional airflow or more space for organizing cables. Additionally, it is equipped with three hydraulic bearing fans, easy-to-clean air filters in all intakes and two front USB 3.0 ports.
Featuring hybrid functionality, the Node 304 case is ideally used as a cool-running file server, a stylish and quiet home theater PC or a powerful gaming system highlighting minimalistic and stunning Scandinavian design and maximum functionality.
- Fractal Design Node 304 - tower - mini ITX
- Product Type
- System cabinet
- Form Factor
- Tower
- White
- I/O Connectors
- 2 x USB 3.0 , 1 x headphones , 1 x microphone
- Supported Motherboards
- Mini-ITX, DTX
- System Cabinet Features
- Fan speed controller
- Power Device
- No power supply (ATX)
- 25 cm x 37.4 cm x 21 cm
- 4.9 kg
- Form Factor
- Tower
- Max Mainboard Size
- Mini ITX
- Mini-ITX, DTX
- Internal Bays Qty
- 6
- White
- Cooling System
- Front: 92 mm fan x 2 / 1300 rpm / removable and washable filter , Rear: 140 mm fan x 1 / 1000 rpm / removable and washable filter , Front: 80/92 mm fan mount x 2 , Rear: 120/140 mm fan mount x 1
- Expansion Bays
- 6 (total) / 6 (free) x internal - 2.5" / 3.5" shared
- Expansion Slots
- 2
- Power Device
- No power supply
- Specification Compliance
- ATX
- 25 cm
- 37.4 cm
- 21 cm
- 4.9 kg
