Fractal Design Define R3 USB 3.0 Computer Case (White)
Quicklinx: 7T53WS00 Mfr#: FD-CA-DEF-R3-USB3-WH
The Define R3 case has contemporary design with maximum functionality and noise absorbing features. The minimalistic, yet stunning front panel design, fitted with noise absorbing material on the inside, creates an aura of exclusivity. The sleek interior is matched with pre-fitted, dense noise absorbing material on the side panels, efficiently absorbing noise and vibrations. You can fit an astonishing total of eight hard drives into this case, using the user friendly HDD-trays. PSU is mounted in the bottom of the case, with a convenient pull-out filter beneath it. Are you one of those users always ending up with a case full of tangled cables? No more. The Define R3 offers a convenient and good looking way of hiding them away. The motherboard has rubber covered holes in which you can easily route the cables behind the motherboard.
  • Contemporary design
Fractal Design Define R3 - tower - ATX
System cabinet
Tower
Arctic white
I/O Connectors
2 x USB 2.0 , 1 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Noise reduction, front panel door, removable dust filter, fan speed controller, front dust filter
No power supply
20.7 cm x 52.1 cm x 44 cm
12.5 kg
Tower
Max Mainboard Size
ATX
Internal Bays Qty
8
Front Accessible Bays Qty
2
Arctic white
Cooling System
Rear: 120 mm fan x 1 / 1350 rpm , Front: 120 mm fan x 1 / 1350 rpm , Front: 120 mm fan mount x 1 , Bottom: 120/140 mm fan mount x 1 , Side: 120/140 mm fan mount x 1 , Top: 120/140 mm fan mount x 2
Expansion Bays
8 (total) / 8 (free) x internal - 3.5" , 1 (total) / 1 (free) x front accessible - 5.25"/ 3.5" shared , 1 (total) / 1 (free) x front accessible - 5.25"
Expansion Slots
7 x Expansion Slot
2 x USB 2.0 , 1 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
5.25" to 3.5" bay adapter
No power supply
20.7 cm
52.1 cm
44 cm
12.5 kg
