Fractal Design Core 1100 Computer Case (Black)
Quicklinx: 9LR9WS00 Mfr#: FD-CA-CORE-1100-BL
Case Form Factor: Tower
Motherboard Form Factor: Mini ATX
Colour: Black
£27.66 ex VAT
£33.19 inc VAT
Despite its extremely small outer dimensions, the Core 1100 mATX case provides everything you need. The stylish, Scandinavian exterior design is matched by the fully painted interior, complete with the signature white details of Fractal Design. The case is optimized for airflow with a straight cooling path, and comes equipped with a pre-installed 120mm fan. The front panel is equipped with dust filters. An innovative vertical hard drive bracket can fit either two 3.5" drives, three 2.5" drives, or one drive of each size. Both the 3.5" drive slots come with silicone vibration dampening grommets
Key features
  • An extremely compact micro ATX case, designed for exceptional airflow and cooling
  • Brushed aluminum-look front panel with a sleek, three-dimensional textured finish
  • One Fractal Design 120mm fans included
  • Easy access I/O on front panel, with audio and both USB 3.0 and USB 2.0 ports
  • Front panel dust filters and closed top and bottom panels help maintaining a dust free interior
  • Innovative vertical HDD bracket, which can hold two 3.5" drives or three 2.5" drives, or one drive of each size
  • Vibration-dampened mounting for both 3.5" drive slots
  • Fully painted interior, with Fractal Design signature white details
  • Mini ITX, Micro ATX motherboard compatibility
  • 2 drive bays of 5,25" , two 3.5" HDD positions or 3 bays 2.5" or one 2.5" and one 3.5"drive positions
  • 4 expansion slots
  • Supports Graphics cards up to 350mm in length may be installed. One or more 3.5" hard drives may interfere with side-mounted power connectors on graphics cards longer than 170 mm
  • Support cooling system: 3 Fan positions (1 fan included)
  • Filtered fan slots in front
  • CPU coolers up to 148 mm in height
  • ATX PSUs, up to 185mm if a typical-length optical drive is mounted
  • 13.5-18.5 mm of space for cable routing behind the motherboard plate
  • Available in Black
  • Case dimensions (WxHxD):175 x 358 x 410 mm
  • Net weight: 3.8 kg
Cooling system
  • Front: 1 - 120mm fans (included is 1 Fractal Design silent 120mm fan, 1200 RPM speed)
  • Rear: 1 - 92mm fan (not included)
  • Side: 1 -120mm fan (not included)
Front interface
  • 1 USB 3.0 and 1 USB 2.0
  • Audio in/out
  • Power button with LED (white)
  • HDD activity LED (white)
  • Reset button
Package contents
  • Core 1100 computer case
  • Accessory box
  • User manual
Fractal Design Core 1100 - tower - mini ATX
System cabinet
Tower
I/O Connectors
1 x USB 2.0 , 1 x USB 3.0 , 1 x audio line-in/headphones , 1 x microphone
Supported Motherboards
microATX, Mini-ATX
System Cabinet Features
Front dust filter
No power supply (ATX12V)
17.5 cm x 41 cm x 35.8 cm
3.8 kg
Tower
Max Mainboard Size
Mini ATX
microATX, Mini-ATX
Front Accessible Bays Qty
2
Cooling System
Front: 120 mm fan x 1 / 1200 rpm , Rear: 92 mm fan mount x 1 , Side: 120 mm fan mount x 1
CPU Cooler Max Height
148 mm
Video Card Max Length
350 mm
Front dust filter
Expansion Bays
2 (total) / 2 (free) x front accessible - 5.25" , Internal - 3x2.5" / 2x3.5" / 1x2.5" and 1x3.5" shared
Expansion Slots
4
No power supply
Specification Compliance
ATX12V
17.5 cm
41 cm
35.8 cm
3.8 kg
Colour: Black
Brand: Fractal Design
