With advanced overclocking capability and a range of connectivity features for today multi-media computing requirements, G41MX-K 2.0 enables you to unleash more power from your computer.
- Intel® Core™2 Quad, Core™2 Duo, Pentium® Dual-Core processors, Socket T (LGA775)
- Supports Intel® 45nm Multi-Core processors
- 1333/1066/800 MHz (FSB)
- Dual channel DDR2 800/667x 2 DIMMs, Max 8GB
- 1* PCIe x16, 1* PCIe x1, 2* PCI
- 4SATAII ,1ATA100
- 7.1 channel by Realtek® ALC888
- Gigabit LAN by Realtek
- 8 USB 2.0 ports
- Foxconn G41MX-K - 2.0 - motherboard - micro ATX - LGA775 Socket - G41
- Product Type
- Motherboard - micro ATX
- Chipset Type
- Intel G41 Express / Intel ICH7
- Processor Socket
- 1 x LGA775 Socket
- Compatible Processors
- Pentium, Core 2 Duo, Core 2 Quad
- Max RAM Size
- 8 GB
- RAM Supported
- 2 DIMM slots - DDR2
- Storage Ports
- 1 x ATA, 4 x SATA
- USB Ports Configuration
- 8 x USB
- Audio
- 6-channel audio
- Microsoft Certification
- Compatible with Windows 7
- Product Type
- Chipset Type
- Max Bus Speed
- 1333 MHz
- Processor Socket
- LGA775 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 8 GB
- Technology
- DDR2
- Bus Clock
- 1066 MHz, 800 MHz, 667 MHz, 533 MHz
- Speed
- PC2-8500, PC2-6400, PC2-5300, PC2-4300
- Dual channel memory architecture
Audio
- 6-channel audio
- Audio Codec
- Realtek ALC662-GR
- Expansion Slots
- 2 x DIMM 240-pin , 1 x PCIe x16 , 2 x PCI , 1 x CPU , 1 x PCIe x1
- Storage Interfaces
- Intel ICH7: SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices , Intel ICH7: ATA-100 -connectors: 1 x 40pin IDC - 1 devices
- 1 x LAN (Gigabit Ethernet) , 1 x PS/2 keyboard , 1 x PS/2 mouse , 4 x USB 2.0 , 1 x VGA , 1 x serial , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x parallel / serial
- Internal Interfaces
- 1 x floppy
- Additional Connectors (Optional)
- 4 x USB 2.0
- Power Connectors
- 4-pin ATX12V connector, 24-pin main power connector
- BIOS Features
- ACPI support, DMI 2.5 support
- Plug and Play, ACPI
- 24.4 cm
- 20.8 cm
Foxconn G41MX-K 2.0 LGA775 G41 DDR2 Intergrated Graphics Micro ATX
