The FortiWiFi 51E is compact, cost-effective, all-in-one security appliance that delivers Fortinet's Connected UTM. Ideal for small business, remote, customer premise equipment (CPE) and retail networks, these appliances offer the network security, connectivity and performance you need.
High-performance network security
The FortiWiFi 51E series provides an integrated set of essential security technologies to protect all of your applications and data. You get advanced threat protection, including firewall, application control, advanced threat protection, IPS, VPN, and web filtering, all from one device that's easy to deploy and manage. -
Advanced features
The FortiWiFi 51E offers an amazing firewall with the advanced threat protection including sandboxing and anti-bot protection, and contextual visibility for enhanced reporting and management. VDOMs on the FortiWiFi 51E let you segment networks to enable guest and employee access, or protect things like cardholder data. You get the flexibility to match your business needs. With a robust internal storage, the FortiWiFi 51E allows you to implement integrated WAN optimization and web caching to improve user productive when securely accessing remote applications and document.
- Fortinet FortiWiFi 51E - security appliance - Wi-Fi
- Security appliance
- Form Factor
- Desktop
- Hard Drive
- 32 GB x 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Firewall throughput: 2.5 Gbps , Firewall latency (64-byte UDP): 180 µs , Firewall throughput: 375000 packets per second , VPN throughput (512-bit IPSec): 200 Mbps , VPN throughput (SSL): 100 Mbps , IPS throughput (HTTP): 800 Mbps , SSL inspection throughput: 250 Mbps , NGFW throughput: 160 Mbps , CAPWAP throughput: 1.9 Gbps
- Capacity
- Concurrent TCP sessions: 1800000 , New sessions per second: 21000 , Firewall policies: 5000 , Gateway to gateway IPSec VPN Tunnels: 20 , Client to gateway IPSec VPN tunnels: 250 , Concurrent SSL VPN users: 80 , Virtual domains: 5 , Number of FortiAP devices: 10 , Number of FortiToken devices: 100 , Number of FortiClient devices: 200
- Power
- AC 120/230 V (50/60 Hz)
- 21.6 cm x 14 cm x 3.65 cm
- 925 g
- Built-in Devices
- 5 port switch
- 21.6 cm
- 14 cm
- 3.65 cm
- 925 g
Processor / Memory / Storage
- Hard Drive
- SSD 32 GB x 1
- Form Factor
- Desktop
- Connectivity Technology
- Wireless, wired
- Switching Protocol
- Ethernet
- IPSec
- Remote Management Protocol
- HTTP
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Capacity
- Firewall protection, VPN support, manageable, antivirus analysis, Intrusion Prevention System (IPS), ASIC VPN, URL filtering, web threat protection, application filtering
- Encryption Algorithm
- SSL, SHA-1, 256-bit AES
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Aerial
- Antenna Qty
- 2
- 2 x 1000Base-T - RJ-45 (WAN) , 5 x 1000Base-T - RJ-45 , 1 x console - RJ-45 , 1 x USB - Type A
- UL, VCCI, C-Tick, ICSA IPSec certified, ICSA Firewall certified, cUL, ICSA Antivirus, CB, FCC Part 15 B, ICSA Network IPS
- Power Device
- External power adapter
- Voltage Required
- 19 Watt
- OS Provided
- FortiOS 5
- 0 °C
- 40 °C
- 20 - 90% (non-condensing)
