Fortinet FortiSwitch 80-PoE Switch
Quicklinx: CJNBWS00 Mfr#: FS-80-POE
The FortiSwitch-80-POE provides full 15.4 watts/port of Power over Ethernet (POE) in a cost-effective form factor for the distributed enterprise or small office. This eight-port GbE switch provides 62 watts of POE power to four devices, the highest in the industry. You can connect wireless access points, IP phones, and IP cameras to the POE ports. The FortiSwitch-80-POE eliminates the need for additional POE injectors, simplifying your small office network while improving performance. The remaining four GbE ports can accommodate uplink ports as well as additional devices such as printers, and back office equipment.
Fortinet FortiSwitch 80-PoE - switch - 8 ports - unmanaged
Switch - 8 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
4 x 10/100/1000 (PoE) + 4 x 10/100/1000
Power Over Ethernet (PoE)
PoE
Performance
Throughput: 2 Gbps
MAC Address Table Size
2K entries
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, full duplex mode
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3af, IEEE 802.3x
12 cm x 19 cm x 3.8 cm
0.75 kg
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
PoE
Performance
Throughput: 2 Gbps
2K entries
Status Indicators
Port transmission speed, power, link/activity
4 x 1000Base-TX RJ-45 , 4 x 1000Base-TX RJ-45 PoE
External power adapter
68.2 Watt
12 cm
19 cm
3.8 cm
0.75 kg
5 - 95% (non-condensing)
Min Storage Temperature
Max Storage Temperature
50 °C
