FortiSwitch data center switche delivers outstanding throughput, resiliency and scalability for organizations with high performance network requirements. It is ideal for top of rack server or firewall aggregation applications, as well as enterprise network core or edge deployments, where high performance 40 GE is required. Purpose-built to meet needs of today's bandwidth intensive data centers and enterprise networks, FortiSwitch data center switche delivers high-performance with a low total cost of ownership.
High-performance and resilient managed data center switch
Designed in a compact 1 RU form factor, FortiSwitch data center switches are equipped with dual hot swappable power supplies to maximize network uptime. With 40 GE access ports and a high-throughput backplane, the FortiSwitch data center switches satisfy the top of rack server or firewall aggregation performance requirements of today's virtualization centric data centers.
- Fortinet FortiSwitch 3032D - switch - 32 ports - Managed - rack-mountable
- Switch - 32 ports - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- 40 Gigabit Ethernet
- Ports
- 32 x 40 Gigabit QSFP+
- Performance
- Switching capacity: 1280 Gbps , Port-to-port latency: 1 µs , Forwarding performance: 2400 Mpps
- Capacity
- Virtual interfaces (VLANs): 4000 , Maximum aggregation groups: 16 , Priority queues per port: 10
- MAC Address Table Size
- 128K entries
- Jumbo Frame Support
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, SSH, CLI
- Flow control, DHCP support, VLAN support, port mirroring, IPv6 support, SNTP support, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, IPv4 support, Link Aggregation Control Protocol (LACP), Management Information Base (MIB), 12MB packet buffer, tagged VLAN
- IEEE 802.3, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1AX
- Power
- AC 120/230 V (50/60 Hz)
- 43.85 cm x 46 cm x 4.35 cm
- 8.8 kg
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Ports
- Performance
- Capacity
- 128K entries
- Routing Protocol
- Static IP routing
- Authentication Method
- Secure Shell (SSH), RADIUS
- 32 x QSFP+ , 1 x 1000Base-T RJ-45 management , 1 x console RJ-45 management
- Power Device
- Internal power supply - hot-plug
- Installed Qty
- 2
- Voltage Required
- 215.3 Watt
- MTBF
- 10 years
- 43.85 cm
- 46 cm
- 4.35 cm
- 8.8 kg
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -25 °C
- Max Storage Temperature
- 70 °C
