The FortiGate-90 series is compact, all-in-one network security appliance that delivera Fortinet's connected UTM solution. Ideal for remote locations, customer premise equipment (CPE) and retail or healthcare networks, the FortiGate-90 series appliance offers the network security, connectivity and performance you need. With connected UTM you get a single device that integrates comprehensive enterprise-grade protection with a broad range of wired and wireless connectivity options. It enables you to deploy a high-performance, highly secure remote infrastructure with one appliance that's easy to set up and centrally manage.
- Fortinet FortiGate 90D-POE - security appliance
- Security appliance
- Form Factor
- External
- Hard Drive
- 32 GB x 1
- Ports Qty
- 16
- Data Link Protocol
- Performance
- Firewall throughput (1518-byte packet size): 3.5 Gbps , Firewall throughput (512-byte packet size): 3.5 Gbps , Firewall throughput (64-byte packet size): 3.5 Gbps , VPN throughput (512-bit IPSec): 1 Gbps , Firewall throughput: 5.3 Mpps , VPN throughput (IPSec): 1 Gbps , VPN throughput (SSL): 35 Mbps , IPS throughput: 275 Mbps , Antivirus throughput: 65 Mbps , Antivirus throughput (proxy): 35 Mbps
- Capacity
- Client to gateway IPSec VPN tunnels: 1000 , Gateway to gateway IPSec VPN Tunnels: 200 , Concurrent sessions: 1500000 , New sessions per second: 4000 , Firewall policies: 5000 , Concurrent SSL VPN users: 200 , Virtual domains: 10 , Number of FortiAP devices: 16 , Number of FortiToken devices: 100 , Number of FortiClient devices: 200
- Power
- AC 120/230 V (50/60 Hz)
- 21.6 cm x 22.3 cm x 4.4 cm
- 1.6 kg
- 21.6 cm
- 22.3 cm
- 4.4 cm
- 1.6 kg
Processor / Memory / Storage
- Hard Drive
- SSD 32 GB x 1
- Form Factor
- External
- Ports Qty
- 16
- Connectivity Technology
- Wired
- Performance
- Capacity
- 3G/4G USB Dongle Support
- 10 x 1000Base-T - RJ-45 , 4 x 1000Base-T (PoE) - RJ-45 , 2 x USB - Type A , 1 x management (USB)
- UL, VCCI, C-Tick, ICSA IPSec certified, ICSA Firewall certified, cUL, ICSA Antivirus, CB, FCC Part 15 B, ICSA Network IPS
- Power Device
- External power adapter
- Voltage Required
- 59 Watt
- 0 °C
- 40 °C
- 20 - 90% (non-condensing)
