Fortinet FortiGate 240D-POE Security Appliance
Quicklinx: CJ6GWS00 Mfr#: FG-240D-POE
The FortiGate-240D delivers high-speed security and performance for campus perimeter and branch office wired or wireless networks. Purpose-built processors provide up to 4 Gbps firewall throughput, enabling protection of your applications and network without affecting availability or performance. High-density GbE interfaces facilitate network growth and expansion. The FortiGate-240D provides comprehensive threat protection with Fortinet's unmatched range of enterprise-grade security technologies. They deliver firewall, VPN (IPSec and SSL), intrusion prevention, antivirus/antispyware, antispam, and web filtering technologies. These comprehensive security components enable you to deploy required technologies most suited for your unique environment.
  • Powerful, secure, easy to install
    FortiASIC purpose-built processors ensure that your security countermeasures will not become a network bottleneck. The FortiASIC CP8 processor delivers deep inspection security components such as application control, IPS and anti-malware. The FortiASIC NP4Lite processor delivers firewall and VPN throughput at switching speeds by performing high-speed processing of network flows. The FortiGate-240D installs in minutes, automatically downloading regular updates to protect against the latest viruses, network vulnerabilities, worms, spam and phishing attacks, and malicious websites with no administrator intervention. Onboard storage provide local archiving of data for policy compliance and/or web caching.
  • Industry validation
    The FortiGate family of physical and virtual appliances has earned more certifications than any other vendor by consistently meeting rigorous third-party standards. The industry-leading technology provides you with air-tight security which you can safely count on.
  • More protection and better ROI
    The FortiGate constantly evolves itself in its mission to provide more value for users. Extended features such as Wi-Fi controller, integrated token server, endpoint control and WAN optimization add more security to organizations without incurring additional cost.
  • Complete and real-time security
    Fortinet FortiGuard Subscription Services provide automated, real-time, up-to-date protection against the latest security threats. The threat research labs are located worldwide, providing 24x7 updates when you most need it.
Fortinet FortiGate 240D-POE - security appliance
Security appliance
External - 1U
Fortinet FortiASIC CP8
Hard Drive
64 GB x 1
Performance
Firewall throughput (1518-byte packet size): 4 Gbps , Firewall throughput (512-byte packet size): 4 Gbps , Firewall throughput (64-byte packet size): 4 Gbps , Firewall latency (64-byte UDP): 6 µs , Firewall throughput: 6 Mpps , VPN throughput (IPSec): 1.3 Gbps , VPN throughput (SSL): 400 Mbps , IPS throughput: 2.1 Gbps , Proxy-based antivirus throughput: 600 Mbps , Flow-based antivirus throughput: 1.1 Gbps
Concurrent sessions: 3200000 , New sessions per second: 77000 , Firewall policies: 10000 , Gateway to gateway IPSec VPN Tunnels: 2000 , Client to gateway IPSec VPN tunnels: 5000 , Virtual domains: 10 , Number of FortiAP devices: 128 , Number of FortiToken devices: 1000 , Number of FortiClient devices: 600
4 rubber feet, rack mount kit
Power Over Ethernet (PoE) Supported
PoE
43.2 cm x 33.4 cm x 4.4 cm
6 kg
Security appliance
Height (Rack Units)
1U
Built-in Devices
Led panel
43.2 cm
33.4 cm
4.4 cm
6 kg
Processor / Memory / Storage
Processors Installed
Hard Drive
SSD 64 GB x 1
External
Wired
Switching Protocol
Ethernet
Network / Transport Protocol
IPSec
Remote Management Protocol
HTTP, CLI
Performance
Status Indicators
Port transmission speed, power, status, alarm, DMZ, link/activity
Firewall protection, DMZ port, power over Ethernet (PoE), VPN support, antivirus analysis, High Availability, Intrusion Prevention System (IPS), firmware upgradable, anti-spam protection, anti-malware protection, IPSec passthrough
Encryption Algorithm
SSL
2 x 1000Base-T - RJ-45 (WAN) , 16 x 1000Base-T - RJ-45 , 24 x 1000Base-T (PoE) - RJ-45 , 1 x console - RJ-45 , 2 x Ethernet 1000 - SFP (mini-GBIC) (DMZ) , 1 x USB - Type B , 1 x USB - Type A , 1 x management - RJ-45
1 x network cable , 1 x console cable , 1 x USB cable
UL, VCCI, C-Tick, ICSA IPSec certified, ICSA Firewall certified, cUL, ICSA Antivirus, CB, FCC Part 15 A, ICSA Network IPS
PoE
Internal power supply
375 Watt
OS Provided
FortiOS 5
Software Included
Drivers & Utilities
20 - 90% (non-condensing)
