The FortiGate 30E are compact, cost effective, all-in-one security appliances that deliver Fortinet's Connected UTM. Ideal for small business, remote, customer premise equipment (CPE) and retail networks, these appliances offer the network security, connectivity and performance you need.
Wireless and 3G/4G WAN extensions
The FortiGate supports external 3G/4G modems that allow additional or redundant WAN connectivity for maximum reliability. The FortiGate can also operate as a wireless access point controller to further extend wireless capabilities. -
Compact and reliable form factor
Designed for small environments, you can simply place the FortiGate 30E on a desktop. It is small, lightweight yet highly reliable with superior MTBF (Mean Time Between Failure), minimizing the chance of a network disruption.
- Fortinet FortiGate 30E - UTM Bundle - security appliance - with 1 year FortiCare 24X7 Comprehensive Support + 1 year FortiGuard
- Security appliance
- Bundled Services
- 1 year FortiCare 24X7 Comprehensive Support + 1 year FortiGuard
- Form Factor
- External
- Flash Memory
- 16 GB
- Data Link Protocol
- Performance
- Firewall throughput: 950 Mbps , Firewall throughput: 180000 packets per second , SSL inspection throughput: 200 Mbps , Firewall latency (64-byte UDP): 130 µs , IPS throughput: 240 Mbps , IPS throughput (HTTP): 600 Mbps , VPN throughput (512-bit IPSec): 75 Mbps , VPN throughput (SSL): 35 Mbps
- Capacity
- Concurrent TCP sessions: 900000 , New TCP sessions per second: 15000 , Firewall policies: 5000 , Gateway to gateway IPSec VPN Tunnels: 20 , Client to gateway IPSec VPN tunnels: 250 , Concurrent SSL VPN users: 80 , Number of FortiToken devices: 20 , Number of FortiClient devices: 200 , Virtual domains: 5 , Number of FortiAP devices: 2
- Power
- AC 120/230 V (50 - 60 Hz)
- 21 cm x 13.3 cm x 4.1 cm
- 899 g
- 1-year warranty
- Bundled Services
- 21 cm
- 13.3 cm
- 4.1 cm
- 899 g
Processor / Memory / Storage
- Flash Memory
- 16 GB
- Form Factor
- External
- Connectivity Technology
- Wired
- Switching Protocol
- Ethernet
- Remote Management Protocol
- HTTP
- Performance
- Capacity
- Firewall protection, VPN support, manageable, antivirus analysis, Intrusion Prevention System (IPS), ASIC VPN, URL filtering
- 1 x 1000Base-T - RJ-45 (WAN) , 4 x 1000Base-T - RJ-45 , 1 x USB - Type A , 1 x console - RJ-45
- UL, VCCI, C-Tick, ICSA IPSec certified, ICSA Firewall certified, cUL, ICSA Intrusion Detection, ICSA Antivirus, CB, FCC Part 15 B
- Power Device
- External power adapter
- Voltage Required
- 13 Watt
- Software Included
- FortiExplorer
- Limited warranty - advance parts replacement - 1 year - response time: next business day , Technical support - phone consulting - 1 year , Product info support - e-mail consulting - 1 year , Product info support - web knowledge base access - 1 year , Technical support - web support - 1 year , New releases update - 1 year , Virus definitions update - 1 year , Intrusion definitions update - 1 year , URL Database update - 1 year , E-mail database update - 1 year
- 0 °C
- 40 °C
- 20 - 90% (non-condensing)
