Fitbit Classic Band - Small - Black - for Fitbit Versa family
Quicklinx: FM4QWS00 Mfr#: FB166ABBKS
Fitbit Versa classic bands are comfortable, swim ready and stain resistant - making them the perfect accessory for everything from a swim at the pool to a walk in the park.
Works with all watches in the Versa family.
Sizing
Small - Fits wrist 140 mm - 180 mm in circumference.
Materials
This classic band is made of a flexible, durable elastomer material similar to that used in many sports watches and includes an aluminium buckle.
Water Resistance
This classic band is water resistant to 50 metres. After swimming or getting the band wet, we recommend drying off the band because, as with any wearable device, it's best for your skin if the band is clean and dry. We do not recommend wearing it in a hot tub or sauna.
Care
If this band gets wet or if you sweat in it, remove and completely dry the band before putting it back on. Give your wrist a rest by taking the band off every now and then.
Fitbit - band for smart watch
Band
Intended For
Smart watch
Band Size
Small
Protection
Water-resistant
Product Material
Elastomer
1-year warranty
Fitbit Versa
Band
Intended For
Smart watch
Band Size
Small
Band Clasp Type
Buckle
Protection
Water-resistant
Product Material
Elastomer
1-year warranty
Fitbit Versa
