Give your routine a boost with Fitbit Charge 6, the only fitness tracker with Google built in. Charge 6 has your essentials—like YouTube Music, Google Maps and Google Wallet—plus the fitness tools you need to crush your goals. From staying motivated and tracking your daily progress to tuning in and taking care, running your day and your routine has never been easier.
40+ exercise modes
With more than 40 unique exercise modes, you can set personal goals for everything from runs, bike rides and aerobics, to HIIT, strength training and more. Stay tuned in with stats relevant to your workout of the moment, whether you’re looking to keep the pace or maintain your target heart rate zone.
24/7 heart rate
Watching your heart rate during exercise lets you know when you’re in fat burn, cardio or peak zones so you know how hard you’re working. The more you can comfortably push yourself, the more benefits you’ll see for your heart.
Active Zone Minutes
When you work out harder, you deserve more credit. Active Zone Minutes tracks the time you spend in your target heart rate zones, giving you double minutes when you’re in cardio or peak. We do the math and show you if you’re hitting the recommended 150 minutes each week.
Cardio fitness level
Get to know your VO2 max—a measurement of how well your body uses oxygen when you’re working your hardest. Keep tabs on your score to see how you improve over time. (Requires Fitbit mobile app)
Built-in GPS
See your pace and distance during outdoor workouts—no phone necessary—using built-in GPS, then see a map of your workout route in the Fitbit mobile app. If you have your compatible phone nearby, Charge 6 connects to its GPS to help extend your tracker's battery.
All-day activity tracking
Just get moving; we’ll take care of the rest. Charge 6 tracks your steps, distance, calories burned & Active Zone Minutes 24/7.
Workout intensity map
After outdoor exercise with GPS, check your workout intensity map in the Fitbit mobile app to see your pace and heart rate zones throughout your route and learn where you put in the most effort.
SmartTrack®
Forget to start tracking? Don’t sweat it. SmartTrack automatically recognizes and records workouts like elliptical, runs, swims and more.
Timer & stopwatch
Get instant access to tools that make your life easier—like a timer for interval training and a stopwatch for tracking sets at the gym.
See it on display
See your heart rate in real-time when you link Charge 6 to your favorite compatible exercise machines like treadmills, ellipticals, rowers, exercise bikes and more. -
Fitness motivation
Choose your mood with music you like and get inspired with over 40 exercise modes. Keep up with your body by tracking your heart rate, steps, distance and calories burned. -
Advanced health tools
Get a read on your beat with up to 60% more accurate tracking during vigorous activities like HIIT, spinning and rowing. -
Get to know your VO2 max and see how well your body uses oxygen when you're working your hardest. -
Sleep Score
Learn about the quality of your previous night's sleep with a personalized Sleep Score. -
SmartTrack
Forget to start tracking? Don't sweat it. SmartTrack automatically recognizes and records workouts. -
Long battery life
Leave your charger behind on your next long weekend trip with a tracker that can go for up to 7 days. -
Stress Management Score
Get a daily score showing your body's physical response to stress-and how your routines can help. -
Navigation button
Find what you need with the easy side button. Just a quick tap lets you jump to your home screen or see your stats.
- Fitbit Charge 6 - silver aluminium - activity tracker with infinity band - porcelain
- Product Type
- Activity tracker
- Tracking Data
- Distance, time, calories burned, sleep activity, heart rate, Resting Heart Rate (RHR), ECG, blood oxygen saturation, skin temperature, breathing rate, menstrual cycle, steps taken
- Connectivity
- Bluetooth, NFC
- Navigation
- GPS/GLONASS/Galileo receiver
- Display
- AMOLED - always-on display
- Case
- Aluminium, glass, resin
- Band
- Porcelain - infinity band - silicone - changeable
- Input
- Touch screen, push button
- Notifications
- High and low heart rate, irregular rhythm, sedentary, alarm, calendar, SMS, applications, incoming calls
- Daily Readiness Score, VO2 max, automatic exercise recognition, reminder of hydration, sleep recommendations, Stress Management Score, Sleep Score, Sleep Profile, smart Wake-Up, music remote handling, find phone function
- Supported Host Device OS
- iOS, Android
- Battery
- Rechargeable lithium polymer
- Battery Run Time
- Up to 7 day(s)
- 18.6 mm x 11.7 mm x 38.7 mm
- 2-year warranty
- Product Type
- Activity tracker
- Android 9.0 (Pie) or later, iOS 15 or later
- Notifications
- Navigation
- Tracking Data
- Modes
- 40+ sports modes, do-not-disturb mode, sleep mode
- Wearing Style
- Wrist
- Feedback Type
- Vibration alert, visual interface
- Clock Display
- Set Goals
- Sensors
- Optical heart sensor, 3-axis accelerometer, SpO2 sensor, temperature sensor, ambient light sensor, multipurpose electrical sensor
Display
- AMOLED - colour
- Always On Display (AOD)
- Wireless Interface
- Bluetooth 5.0 LE, NFC
Input Device
- Touch sensitive screen, push button
- Technology
- Lithium polymer
- Rechargeable Battery
- Run Time (Up To)
- 7 day(s)
- Recharge Time
- 2 hour(s)
Smart Watch Case
- Case Details
- Silver aluminium
Band
- Name
- Infinity band
- Changeable
- Clasp Type
- Loop and peg
- Material
- Silicone
- Porcelain
- 18.6 mm
- 11.7 mm
- 38.7 mm
- Preloaded Software
- Timer, Stopwatch, Google Maps, Google Wallet
- Vibrating Alert
- Body Material
- Protection
- Water-resistant
- ISO 22810
- Included Accessories
- Charging cable, wristband (Large), 6-month Fitbit Premium membership
- Warranty
- 2-year warranty
- Max Depth of Water Resistance
- 50 m
- -10 °C
- 45 °C
- Max Altitude Operating
- 8000 m
