Get a more complete picture of your health with the Fitbit Aria Air smart scale. This easy to use smart scale displays your weight and syncs it to the Fitbit app where you can view your BMI, track your trends over time and see how things like activity and nutrition impact your goals.
Weight + More
Tracks more than weight by showing your BMI in the Fitbit app.
Easy Smartphone Set-up
Set up your scale in minutes. Use your smartphone's Bluetooth connection to start using Aria Air.
Tracker Compatible
Connects to the Fitbit app where it works alongside Fitbit smartwatches and trackers to give you a better understanding of how your activity impacts your weight.
Charts and Graphs
See your trends and track progress in easy-to-read charts and graphs on the Fitbit dashboard.
Wireless Syncing
Aria Air syncs stats wirelessly to computers and 200+ leading iOS and Android devices via a Bluetooth connection.
Works With Fitbit App
See your progress over time and get the motivation to keep pushing towards your goals.
Simple and accurate
In a single step, Aria Air tracks your weight and syncs your stats to the Fitbit app where you can see your BMI based on your weight and profile information. -
Use with Fitbit watches & trackers
Aria Air syncs to the Fitbit app where it works alongside Fitbit watches and trackers to give you more tools to help you reach your health and fitness goals. Wear your watch or tracker to record things like exercise, sleep and more and sync all of your stats to the Fitbit app. -
Easy smartphone setup
Set up your scale in minutes using your smartphone's Bluetooth wireless technology and following the quick start guide. -
Syncs wirelessly via Bluetooth
Using your smartphone's Bluetooth wireless technology, Aria Air syncs your stats to your Fitbit account where they are compiled into simple charts and graphs that let you see your progress over time. -
See your progress on the dashboard
Track your weight on your Today dashboard and see your progress over time via easy-to-read charts and graphs on the Fitbit app. -
Works with multiple users
Aria Air allows multiple users to measure their weight when their phone is connected to the scale. Just open the Fitbit app, step on the scale and Aria Air will display your weight and sync to your Fitbit account over Bluetooth. -
Log food, workouts and more
Understand your calories in vs. calories out by recording meals and exercise in the Fitbit app and comparing the data against your weight trends for a more complete picture of your health.
- Fitbit Aria Air Smart - bathroom scales - white
- Product Type
- Bathroom scales - electronic
- White
- 30 cm x 30 cm x 2.57 cm
- 1.79 kg
- 2 year warranty
- Product Type
- Category
- Personal health
- White
Scales
- Measuring Functions
- Body mass index (BMI)
Settings, Controls & Indicators
- Smartphone Compatible
Display
- Digital
Internet of Things (IoT)
- Communications Technology
- Bluetooth
- 30 cm
- 30 cm
- 2.57 cm
- 1.79 kg
- Warranty
- 2 year warranty
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
FD7Y 048258 Condition: Customer return - item has been used and shows signs of use |
£12.51 |
Legend
- This part of the stock item is present and in good condition
- This part of the stock item is not present or functional
- This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
- This part of the stock item is not applicable e.g. it might not include accessories or software as standard
- This item has not been tested.
