FileMaker Pro 12 Complete Package - 1 User - DVD - Windows, Mac
Quicklinx: 8774WS00 Mfr#: H6316Z/A
FileMaker Pro is an easy-to-use database software for Windows and Mac OS that helps you manage people, projects, assets and more - the easy way! The award-winning ease of use that is built into every aspect of FileMaker Pro continues to be praised by millions of customers and industry experts around the world. With its easy installation and setup, you'll be up and running in a matter of minutes - not hours or days.
Then a few clicks will convert your Microsoft Excel spreadsheets and other files to FileMaker databases for easier searching, sorting, printing and reporting.
The intuitive point-and-click interface helps you customize solutions and share them with ease. So whether you're tracking a simple contact list or multiple project tasks, FileMaker Pro helps you manage it all - faster and easier than ever before!
  • FileMaker charts
    Create eye-catching reports using bar, line, area, and pie charts.
  • Quick reports
    Make reports in a spreadsheet-like format. Group and summarize data on the fly.
  • Enhanced layout/report assistant
    More streamlined interface guides you step-by-step in building reports with grouped data.
  • Recurring import
    Automatically import Microsoft Excel and text files every time you open your database.
  • Snapshot link
    Save a specific set of records at a point in time. Preserve the same layout, view, and sort order.
  • Quick find
    Search for information just as you would in a web browser.
  • Inspector
    Manage your layout tools all in one convenient place.
  • Object badges
    Visually identify different properties in your layouts with more color-coded icons.
  • Invoice starter solution
    Create, manage, and print customized invoices for every order.
  • Improved quick start screen
    Create a database, manage favorite files, or find helpful resources - all from one screen.
  • Text highlighting
    Identify key text in your layouts.
  • Layout folders
    Organize all your layouts in folders - just drag and drop.
  • Portal filtering
    Specify related records based on calculations.
  • Scripting enhancements
    Create and modify scripts from anywhere you can select a script including button setup, script triggers, and custom menus.
  • External file protection
    Prevent unauthorized access to tables, scripts and value lists.
  • Variables in find requests and merge fields
    Use variables in scripted finds and merge fields to simplify your database schema.
  • Instant web publishing enhancements
    Instant web publishing supports FileMaker charts, portal filtering and features the same user interface as FileMaker Pro.
FileMaker Pro (v. 12) - box pack - 1 user
Box pack
Category
Business applications - databases / database tools
Version
12
Licence Qty
1 user
Platform
Windows, MacOS
Distribution Media
DVD-ROM
Category
Box pack
Version
12
Platform
Windows, MacOS
Distribution Media
DVD-ROM
Licencing
Licence Qty
1 user
Supported OS
Microsoft Windows 7 Professional, Microsoft Windows 7 Home Premium, Microsoft Windows 7 Ultimate, Microsoft Windows Vista Home Premium SP2, Microsoft Windows Vista Business SP2, Microsoft Windows Vista Ultimate SP2, Apple MacOS X 10.6, Microsoft Windows XP Professional SP3, Microsoft Windows XP Home Edition SP3, Apple MacOS X Lion 10.7, Windows 8, Apple OS X 10.8 Mountain Lion, Windows 8 Pro
Hardware Requirements
Microsoft Windows Vista / 7 / 8 - 1 GHz - RAM 1 GB , Microsoft Windows XP - 700 MHz - RAM 256 MB , Apple OS X 10.8 Mountain Lion - Core 2 Duo RAM 2 GB , Apple MacOS X Lion 10.7 - Intel x86-64 RAM 2 GB , Apple MacOS X 10.6 - Intel x86-64 RAM 1 GB
Additional Requirements
DVD-ROM, 1024 x 768 monitor resolution
