Fellowes Shredder 125Ci Cross-Cut
Quicklinx: 94B6WS00 Mfr#: 4612101
£647.61 ex VAT
£777.13 inc VAT
The Powershred 125Ci 100% Jam Proof Shredder is a powerful cross-cut machine, ideal for up to 5 users in small office environments. The SilentShred Technology minimises noise disruption, and the extended run time allows you to shred continuously for up to 45 mThe Powershred 125Ci 100% Jam Proof Shredder is a powerful cross-cut machine, ideal for up to 5 users in small office environments. The SilentShred Technology minimises noise disruption, and the extended run time allows you to shred continuously for up to 45 minutes, making the 125Ci ideal for high volume shredding in shared work spaces. The machine shreds up to 18 sheets per pass into 4x38mm particles (Security Level P-4) so you can be sure that sensitive information has been disposed of securely. The 100% Jam Proof feature brings you the latest in advanced jam prevention, eliminating paper jams and powering through tough jobs, while the SafeSense Technology immediately stops the motor when hands touch the paper entry, for peace of mind when shredding. The 125Ci features a built in Energy Saving System that reduces in-use energy consumption by up to 70% when in use and powers down after periods of inactivity. This machine has a 230mm paper entry featuring a flap specifically for shredding CD's. As well as CD's this machine shreds staples, paper clips and credit cards. The generous 53 litre pull out bin allows for easy waste disposal and reduces the need for frequent emptying. The 125Ci comes with 2-year product and service warranty plus 20-year on cutters. .inutes, making the 125Ci ideal for high volume shredding in shared work spaces. The machine shreds up to 18 sheets per pass into 4x38mm particles (Security Level P-4) so you can be sure that sensitive information has been disposed of securely. The 100% Jam Proof feature brings you the latest in advanced jam prevention, eliminating paper jams and powering through tough jobs, while the SafeSense Technology immediately stops the motor when hands touch the paper entry, for peace of mind when shredding. The 125Ci features a built in Energy Saving System that reduces in-use energy consumption by up to 70% when in use and powers down after periods of inactivity. This machine has a 230mm paper entry featuring a flap specifically for shredding CD's. As well as CD's this machine shreds staples, paper clips and credit cards. The generous 53 litre pull out bin allows for easy waste disposal and reduces the need for frequent emptying. The 125Ci comes with 2-year product and service warranty plus 20-year on cutters.
  • Performant Shredding
    Superior 100% Jam Proof small office shredder with slim design for shared use
Fellowes Powershred 125Ci - shredder
Shredder
Localization
United Kingdom
Security Level
S3
Cut Type
Cross-cut
Shred Size
4 x 38 mm
Wastebin Capacity
49 litres
Number Of Sheets At Time
18
Paper Entry Width
23 cm
Shreds
CDs, credit cards, staples, paper clips, paper
73.2 cm x 28 cm x 52 cm
26.7 kg
2 years
Shredder
Localization
United Kingdom
Warranty Details
Machine: 2 years , Cutter: 20 years
Shredder
Security Level
S3
Cut Type
Cross-cut
Shred Size
4 x 38 mm
Wastebin Capacity
49 litres
18
Paper Entry Width
23 cm
Shreds
Continuous Run Time (minutes)
30
Anti-Jam Technology
Jam Proof System, SafeSense, SilentShred
73.2 cm
28 cm
52 cm
26.7 kg
Brand: Fellowes
Price Range Ex VAT: £500 - £750
