Fellowes MS450CS MICROSHRED SHREDDER
Quicklinx: 7Q25WS00 Mfr#: 3245101
The Powershred MS-450Cs Micro-Cut Shredder offers superior protection, shredding paper into 10 times smaller particles than standard cross-cut shredders. The SilentShred Technology offers ultra-quiet perfThe Powershred MS-450Cs Micro-Cut Shredder offers superior protection, shredding paper into 10 times smaller particles than standard cross-cut shredders. The SilentShred Technology offers ultra-quiet performance, making this machine ideal for shared workspaces with 1-3 users. The MS-450Cs shreds 7 sheets per pass into 2x8mm particles (Security Level P-5), cutting each piece of A4 paper into over 2,000 pieces, making highly confidential information virtually impossible to assemble and read. The sturdy cutters can also shred staples, credit cards and CD's and can shred continuously for up to 10 minutes. For added peace of mind when shredding the MS-450 features innovative SafeSense Technology that stops shredding when hands touch the paper entry, it features wide 230mm paper entry plus a designated slot for CDs. As well as the advantage of superior protection, smaller particles take up less space in the waste bin, this means you won't have to empty the 20 litre pull out bin as frequently. This machine comes with a 2-year product and service warranty plus 5-years on cutters.workspaces with 1-3 users. The MS-450Cs shreds 7 sheets per pass into 2x8mm particles (Security Level P-5), cutting each piece of A4 paper into over 2,000 pieces, making highly confidential information virtually impossible to assemble and read. The sturdy cutters can also shred staples, credit cards and CD's and can shred continuously for up to 10 minutes. For added peace of mind when shredding the MS-450Cs features innovative SafeSense Technology that stops shredding when hands touch the paper entry, it features wide 230mm paper entry plus a designated slot for CDs. As well as the advantage of superior protection, smaller particles take up less space in the waste bin, this means you won't have to empty the 20 litre pull out bin as frequently. This machine comes with a 2-year product and service warranty plus 5-years on cutters.
  • Performant Shredding
    Ultra quiet and superior security shredder
Fellowes MicroShred MS-450Cs - shredder
Shredder
Security Level
S4
Cut Type
Micro-shred
Shred Size
2 x 8 mm
Wastebin Capacity
20 litres - 480 sheets
Number Of Sheets At Time
7
Speed
2.7 m/min
Paper Entry Width
22 cm
Shreds
CDs, credit cards, staples, paper
Voltage
120 V
34.9 cm x 26.4 cm x 56.8 cm
16.5 kg
5 years
Shredder
Warranty Details
Cutter: 5 years
Shredder
Security Level
S4
Cut Type
Micro-shred
Shred Size
2 x 8 mm
Wastebin Capacity
7
Speed
2.7 m/min
Paper Entry Width
22 cm
Shreds
Continuous Run Time (minutes)
8-10 on/15 off
Motor Reverse
Autostart
Yes (electronic)
Autostop
Yes (electronic)
Wheels
Anti-Jam Technology
Caster wheels, SafeSense, Interlock Switch, auto stop on jamming, additional wastebin included
Voltage
120 V
Frequency
60 Hz
Power Consumption
4.5 Ah
34.9 cm
26.4 cm
56.8 cm
16.5 kg
