Fellowes JUPITER A3 LAMINATOR 230V
Quicklinx: 80SLWS00 Mfr#: 5701801
Designed for frequent use in the office environment, the Jupiter A3 laminator offers 100% Jam Free performance with Fellowes branded pouches and an Easi-Access mechanism which allows cleaning and maintainance of the rollers for consistently high quality laminating results. It features HeatGuard Technology as well as a Sleep Mode which is activated after periods of inactivity to reduce energy consumption. Jupiter A3 laminates up to 175 micron pouches and comes with 2 year warranty and a starter kit for laminating 10 documents.
  • Office laminator
    High performance 4 roller office laminator offering consistent, quality results
Fellowes Jupiter A3 - laminator
Laminator
Heat or cold laminator
Maximum Working Width
33 cm
Max Thickness
3 mm
Motorized
Laminating Material Thickness
80-175 µm
Laminator
55.5 cm
24.5 cm
12 cm
6.76 kg
Shipping Weight
8.2 kg
Mounting & Laminating
33 cm
Maximum Speed
50 cm/min
Maximum Working Size
A3
Max Thickness
3 mm
Motorized
80-175 µm
Temperature Settings Qty
5
Anti Jam Mechanism
Anti-jam system
Auto Shut Off
AC 230V / 50/60 Hz
Warranty
2 years
