Fellowes, the maker of the world's toughest shredders, is proud to introduce the AutoMax 300C, the first, truly walk away line of shredders. With Fellowes proprietary SureFeed Technology the shredder does the work for you, so you can focus on other priorities. Instead of manually feeding the shredder, materials are loaded into the convenient, pull-out drawer and up to 300 sheets can be securely shredded with just the push of a button. Experience what a true auto feed shredder should be, hands-free and hassle-free.
Unlike other auto-feed shredders which have specific limitations for shredding materials, AutoMax offers the superior advantage of proprietary SureFeed Technology for ease of use, versatility and reliable performance. No more wasting time and effort "preparing" documents, Fellowes AutoMax 300C does it all! Shred crumpled paper, double sided color printed paper, glossy paper, multiple sheets folder over, paper clips, staples - even junk mail and DVDs. Experience what a true auto feed shredder should be, hands-free and hassle-free. Simply load, lock and walk away.
Automatic shredding for maximum productivity
Fellowes, the maker of the world's toughest shredders, is proud to introduce the AutoMax 300C, the first, truly walk away line of shredders. With Fellowes proprietary SureFeed Technology the shredder does the work for you, so you can focus on other priorities. Instead of manually feeding the shredder, materials are loaded into the convenient, pull-out drawer and up to 300 sheets can be securely shredded with just the push of a button. Experience what a true auto feed shredder should be, hands-free and hassle-free. -
Auto feed technology
Unlike other auto-feed shredders which have specific limitations for shredding materials, AutoMax offers the superior advantage of proprietary SureFeed Technology for ease of use, versatility and reliable performance. No more wasting time and effort "preparing" documents, Fellowes AutoMax 300C does it all! Shred crumpled paper, double sided color printed paper, glossy paper, multiple sheets folder over, paper clips, staples - even junk mail and DVDs. Experience what a true auto feed shredder should be, hands-free and hassle-free. Simply load, lock and walk away. -
Basic jam prevention
Paper jams are the frustration among shredder users. That's why Fellowes shredders are engineered to take on every job, no matter how tough. The 300C features JamGuard System to prevent shredding interruptions for jam free operation. -
Enhanced security
With identity theft and data breach concerns at an all-time high, the need to protect personal information is more important than ever. Not only does shredding in-house provide immediate security and peace of mind that materials have been destroyed, but AutoMax's SmartLock engages with each shred cycle to protect confidential information. Even in the event of a power outage, the drawer will remain locked until the shredding cycle is complete. -
Ultra-quiet performance
The shredding doesn't have to be noisy! The 300C features ultra-quiet SilentShred performance, a technology that virtually eliminates loud shredder noise. Now you can shred any time you like without noisy interruptions. -
Energy efficiency
The 300C also features Sleep Mode energy saving feature that shuts down the shredder after two minutes of inactivity. -
Superior performance
With a convenient pull-out drawer for front loading of materials to be shred and cross-cut capability, it easily cuts through credit cards, paper clips, staples, CD/DVDs, junk mail and more while ensuring confidential documents are shredded into unreadable pieces.
- Fellowes AutoMax 300C - shredder
- Shredder
- Security Level
- P-4, O-3, T-4
- Cut Type
- Cross-cut
- Shred Size
- 4 x 38 mm
- Wastebin Capacity
- 60 litres
- Number Of Sheets At Time
- 300
- Paper Entry Width
- 220 mm
- Shreds
- CDs, credit cards, staples, paper clips, paper, DVDs
- 43 cm x 67.3 cm x 88.8 cm
- 45 kg
- 2 years
- Shredder
- Warranty Details
- Machine: 2 years , Cutter: 20 years
Shredder
- Security Level
- P-4, O-3, T-4
- Cut Type
- Cross-cut
- Shred Size
- 4 x 38 mm
- Wastebin Capacity
- 60 litres
- 300
- Paper Entry Width
- 220 mm
- Shreds
- Continuous Run Time (minutes)
- 30
- Recommended Number of Users
- 3-5
- Pull-Out Bin
- Anti-Jam Technology
- Automatic sleep mode, SilentShred, JamGuard System, Smart Lock
- 43 cm
- 67.3 cm
- 88.8 cm
- 45 kg
