Fairphone USB Charger
Quicklinx: FTP4WS00 Mfr#: 000-0021-000000-0003
While the Fairphone 3 battery lasts a full day on average, sometimes your days call for a bit of extra power. Using the Fairphone USB Charger, your battery charges much faster than with a regular charger, so you’re ready to go in no time!
Technical specifications:
Model: DBS15QB
Qualcomm Quick Charge 3.0
Input: 100-240V~50/60Hz 0.5A
Output: 5.0V / 3.0A/9.0V / 2.0A/12.0V / 1.5A 18.0W MAX
Average active efficiency: 82.6%
Efficiency at low load (10%): 78.8%
No-load power consumption: 0.04W
Efficiency level: VI
Color: black
Please note: the USB charging cable is sold separately
Fairphone DBS15QB power adapter - USB - 18 Watt
Power adapter
United Kingdom
Output Connector Type
USB
AC 100-240 V (50/60 Hz)
Voltage Provided
5 / 9 / 12 V
Max Electric Current
3 A
Fast Charge Technology
Power Provided
18 Watt
Fairphone 3, 3+
Power adapter
Mobile phone
Enclosure Colour
United Kingdom
Voltage Provided
5 / 9 / 12 V
Output connectors
4 pin USB Type A
Power Provided
18 Watt
3 A
Fairphone 3, 3+
