Fairphone True Wireless Earbuds deliver an immersive listening experience, with superior sound quality and active noise cancelling. More importantly though, they’re designed with fair and recycled materials, a battery that outlasts your longest playlist and weather resistance for extra peace of mind. This is what true innovation sounds like.
Fair & recycled materials Innovating where it counts with Fairtrade gold in the supply chain and recycled plastics.
Industry-leading battery life Designed with our dedication to get the longest battery lifetime possible.
Superior sound quality The dynamic drivers deliver well-balanced sound quality to match all your favourite playlists.
Hybrid Active Noise Cancelling (ANC) Your sound, your choice. Tune into or out of the world around you with ANC or transparent mode.
Weather resistant Take your sound wherever you go and don’t worry about the elements.
In-ear detection These earbuds know when you’re listening. All you have to do is put them in.
Great sound, sustainably sourced Great sound quality, intuitive controls and a seamless experience are one thing. True to our roots, though, the real innovation happens behind the scenes.
Powered to last At Fairphone, we’re seasoned experts at swimming against the stream. We approach design to solve problems, rather than create new ones. So, we found a solution for the short battery life spans of most wireless earbuds out there.
Your sound. No distractions Zone out or tune back in - the choice is yours. Uninterrupted solo listening sessions of your favourite podcast or that new album you love? Active Noise Cancelling mode has got you covered. Two microphones in each earbud detect ambient noise and the ANC technology works its magic by blocking out unwanted sound. And if you’re on the go, just switch to transparency mode and let the world back in. By adapting the charging speed of both the charging case and the earbuds, we’re confident that our True Wireless Earbuds will last twice as long. And yes, we’re talking years here. Both the earbuds and the charging case are made with 30% recycled plastics. And as a world-first, we managed to integrate Fairtrade Gold into the supply chain.
No matter the weather Fairphone True Wireless Earbuds are IPx4 rated weather resistant. Of course they are, we’re a Dutch company after all. So, we had to make sure rain won’t ever stop the music. We’ve also added three different sizes in ear tips, so the Earbuds sit comfortably in every ear out there. Combine that with the sweat resistance and you’ve got a great fit for workouts, sports and other active lifestyles.
Seamlessly wireless We've put a lot of effort into matching the great sound quality with an intuitive user experience. So pairing, connecting and listening are as easy as taking (one or both of) the Fairphone True Wireless Earbuds out of the recharging case and putting them into your ears. A single tap to answer a call or a double tap gets you back to your music. Simply press and hold to toggle Transparency mode when you are on the go. That's all, rock 'n roll.
Controls - Single & double tap touch controls, In-ear detection
Bluetooth & Wireless - Bluetooth 5.3 with an open-air Bluetooth range up to 10M
Connectors & Charging - USB Type C
Battery - Charging time, 2h for the case, 90 min for earbuds. Talk/play time 5h, Stand by time 180 Days
Microphone - 2 Microphones in each earbud with sound through mode and digital noise cancellation using ANC
Weather resistant - IPx4 Rating
Compatibility - Fairphone 3, Fairphone 3+, Fairphone 4 & any device with Bluetooth
Materials - Earbuds and Charging case contains 30% recycled plastic
In the box
Earbuds and charging case
3 ear caps in different sizes
Quick user guide
Charging cable sold separately
