Fairphone Dual Charger V1 18W/30W UK
Quicklinx: GNV7WS00 Mfr#: ACCHAR-202-UK1
Device Type: Fairphone 4
Type: Charger
Product Range: Fairphone
Product Model: Fairphone 1/2/3/3+/4
£14.16 ex VAT
£16.99 inc VAT
What can this little charger do? Spoiler alert, it's all in the name. It has two ports, USB-A and USB-C, supports fast-charging technology and reliably charges a broad range of devices
Fairphone designed this versatile dual-port charger to be your go-to solution for quick and efficient power-ups. It’s compatible with a range of electronic devices, like the Fairphone 3(+) and of course the Fairphone 4. And get this, with its 30W power delivery it will jumpstart the battery of your Fairphone 4 to 50% in just 30 minutes. Add to that the 18W USB-A port and you’ve got one very well-rounded charger. And it wouldn’t be a Fairphone charger, if we didn’t do our best to include recycled plastic in its housing
Ports
  • 1x USB-A 18w
  • 1x USB-C 30W
More Information
  • Compatible with Fairphone 4, Fairphone 3+, Fairphone 3, Fairphone 2, Fairphone 1
  • 2-year warranty
  • Color Black
  • Longueur 90mm
  • Width 28mm
  • Thickness 47mm
  • Weight 74g
Cables not included
Type: Charger
Brand: Fairphone
Stock Status: While stocks last
Stock Status: Clearance
