Protective Case
Because accidents happen. Because it’s better to be safe than sorry. Because it looks really good too!
RECYCLED MATERIALS
It’s made from non-toxic 100% post-consumer recycled TPU (thermoplastic polyurethane).
SHOCK ABSORPTION
It fits perfectly to your phone, absorbing shocks for maximum protection.
PHONE COMPATIBILITY
Made for the Fairphone 5 only.
WHAT IS IN THE BOX
Only the Fairphone 5 Protective Soft Case. We like to minimize waste.
Eco-friendly design
Crafted entirely from recycled thermoplastic polyurethane (TPU), this protective case not only safeguards your cell phone but also supports environmental sustainability. Its 100% recycled content underscores a commitment to reducing waste and promoting eco-friendly products. -
Durable protection
The soft, shock-absorbent material of this back cover ensures your device is protected from drops and impacts. The thermoplastic polyurethane (TPU) construction offers a resilient barrier against daily wear and tear, keeping your cell phone in pristine condition.
- Fairphone - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- 7.9404 cm x 1.17 cm x 16.481 cm
- 30.84 g
- Material
- Thermoplastic polyurethane (TPU)
- Sky blue
- Product Recycled Content
- 100 % - made of recycled thermoplastic polyurethane (TPU)
- 2-year warranty
- Designed For
- Fairphone 5
- 7.9404 cm
- 1.17 cm
- 16.481 cm
- 30.84 g
- Material
- Sky blue
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Shock-absorbent
- Cover Type
- Back cover
- Soft
- Limited warranty - 2 years
- Designed For
- Fairphone 5
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
HD9K 050224 Condition: Customer return - item has been used and shows signs of use |
£3.74 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
