Sustainable. Long-lasting. Fair.
A quality smartphone with fairness at its core
Sustainability has never been this powerful. Designed to last, with fair and recycled materials, the Fairphone 4 brings you 5G speed, with great battery life and a premium dual-camera - all backed by our 5-year warranty*.
Fairphone 4 comes with:
5G
E-waste neutral
Fair and recycled materials
5-year warranty*
8GB RAM, 256GB Internal memory
48MP dual rear cameras with supporting sensor and 25MP selfie camera
Design
Fairphones are made to be repaired thanks to their modular designs
Material sourcing
Fairphones are produced using recycled and fair materials
Workers welfare
Fairphone has programs to ensure better working conditions for factory workers
Reusing and recycling
Fairphone encourages repairs and provides a take back program
Modular and Repairable
You don’t need to be an expert to swap out the battery or display. No part of Fairphone 4 is glued shut, so you can choose to easily repair it yourself with a standard screwdriver.
Good for the world, easy on your wallet.
What's in the box
Fairphone 4
Quick-start guide
Eco-friendly packaging
Sold separately
Charging Cable
Dual Port 30W Charger
Does not include any tools
*2-year standard warranty. For Fairphone 5 year extended warranty, please refer direct to Fairphone.
Fairtrade Gold, recycled materials
The phone's body is machined from aluminium from ASI certified vendors, with a 100% recycled plastic back cover. -
Beautiful display of design
With its immersive 6.3inch Full HD+ display, smooth aluminium body and soft, recycled back cover the Fairphone 4 is a statement of industrial design, boldly unique in its look and feel. This device is a challenge to the industry to rethink the modern smartphone: True innovation should be about solving problems, rather than creating new ones. This purpose of design shines through in every aspect of the Fairphone 4. It's what makes it beautiful. -
Super fast 5G speed
Video call your friends in HD, stream high-quality music and even download movies on the move. 5G opens up new possibilities. No rush, get started with your existing SIM card and switch over when you're ready. Once you do, your Fairphone 4 will keep you 5G-connected throughout Europe. Fairphone 4 even provides the flexibility to use two SIM cards, introducing an e-SIM slot for an additional number. -
Dual cameras for the win
The Fairphone 4 dual cameras are the real deal. A pair of premium lenses for all the details or the bigger picture. Add a light sensor for blazing fast autofocus and top it off with optical image stabilization for uncompromising image quality. And that counts for the buttery smooth 4K video as well, of course.
- Opperating System
- Android 11
- Performace
- Qualcomm Snapdragon 750G
- Storage
- 8GB Ram, 256GB Internal Storage
- Battery
- 3905mAh Removable Li-Ion Battery
- Display
- 6.3 inch Full HD+
- Cameras
- Dual 48MP rear camera, 25MP Selfie Camera
- Wireless
- Wi-Fi Dual Band, Bluetooth 5.1, NFC For Cardpayments
- Network
- Dual 5GB Sim
- Connectors & Sensors
- USB Type - C, Fingerprint Scanner
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
GJBM 051136 Condition: Customer return - item has been repaired under warranty by the manufacturer |
£165.75 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
