Ezviz Outdoor Colour Night Vision Pan Tilt with AI Human Detection
Quicklinx: H0WCWS00 Mfr#: CS-C8C-A0-1F2WFL1
  • microSD Card
Break the sight boundaries.
The C8C is EZVIZ’s first outdoor WiFi Pan/Tilt Camera, a giant breakthrough combining an exquisite design with comprehensive functionality. Capturing more details than ordinary outdoor cameras do, this camera ensures reliable, all-around outdoor protection.
See everything in clear detail.
This camera captures 1080p high-definition video and images, recording every moment with sharp clarity.
A better day begins with better vision.
Your surroundings are covered with this outdoor pan/tilt camera. With a 352° horizontal rotation and 95° vertical rotation,the C8C gives you an easy overview of all that’s around you.And the EZVIZ App puts it all right on your smartphone or mobile device.
AI-powered person detection.
Smarter than ever! As an upgrade from simple motion detection, the embedded AI algorithm intelligently detects the motion of human shapes in real time. When people enter your customized detection area, you will be alerted immediately.
Three night vision modes are available to meet any need.
  • Full-color night vision - Your night vision is now lit up and vividly restored to full-color thanks to two built-in spotlights and professional optical lenses
  • Black-and-white night vision - If you don't need extra lighting, just switch the camera to the black & white night vision via the EZVIZ App and still see 30 meters (100 ft.) away
  • Smart night vision - In this mode, the C8C will automatically switch from black-and-white monitoring to color monitoring, turning on the spotlights when it detects human movement. The alert video will be recorded in full-color, so you get all the details needed. Now that’s pretty smart!
Strobe light for enhanced protection.
Coming with two spotlights for active protection, the camera allows you to manually flash the light via the app or set it to flash upon detection of people passing by.
Elegant and durable design.
Say goodbye to bulkiness. This camera adopts a novel round and compact design with a simple black and white housing. It’s stylish enough to embellish your life but simple enough to look good anywhere.
What’s more, its weather proof design keeps it operating without being interrupted by any kind of weather – wind, rain, or snow.
Hear what’s happening.
The built-in noise-canceling microphone picks up clear audioand lets you hear and see what’s happening in your backyard wherever you are.
  • See everything in clear detail
  • A better day begins with better vision
    Your surroundings are covered with this outdoor pan/tilt camera. With a 352° horizontal rotation and 95° vertical rotation, the C8C gives you an easy overview of all that's around you. And the EZVIZ app puts it all right on your smartphone or mobile device.
  • AI-powered person detection
  • Strobe light for enhanced protection
  • Elegant and durable design
    Say goodbye to bulkiness. This camera adopts a novel round and compact design with a simple black and white housing. It's stylish enough to embellish your life but simple enough to look good anywhere. What's more, its weather proof design keeps it operating without being interrupted by any kind of weather - wind, rain, or snow.
  • H.265 video technology
    The C8C features the advanced H.265 video compression technology, achieving better video quality with only half the bandwidth and half the storage space of the previous video compression standard (H.264).
EZVIZ C8C - network surveillance camera
Network surveillance camera - pan / tilt - outdoor
Audio
Yes: built-in microphone
14.9 cm x 15.8 cm x 15.7 cm
510 g
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Optical Sensor Type
PS CMOS - 1/2.7" - 2 MP
Minimum Illumination
0.5 lux F1.6 - AGC on , 0 lux - IR
Focal Length Control
Fixed focal
Focal Length
4 mm
Lens Mounting
M12 mount
Lens Iris
F/1.6
Panning Range (degree)
352
Tilting Range (degree)
95
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Voltage
DC 12 V
Backlight Compensation (BLC), infrared cut filter, Digital Wide Dynamic Range (D-WDR), dual video stream, password protection, cloud recording, WPA, WPA2-PSK, 64-bit WEP, 128-bit WEP, WPA-PSK, WPA2, watermark, heartbeat, anti-flicker, 3D digital noise reduction (DNR), self-adaptive shutter, AI Person Detection
Environmental Parameters (operating)
-30 °C - 60 °C; 0 - 95% (non-condensing) relative humidity
Audio Support
Wired, wireless
14.9 cm
15.8 cm
15.7 cm
510 g
Camera
Colour - Day&Night - pan / tilt - outdoor
Digital Video Format
H.264, H.265
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Infrared LEDs
Infrared Distance
30 m
Digital Video Capture Resolution
1920 x 1080
Image Sensor
2 MP PS CMOS 1/2.7"
Lens Construction
M12 mount - fixed focal
Focal Length
4 mm
Lens Iris
F/1.6
Horizontal Field of View (degree)
87
Diagonal Field of View (degree)
105
Panning
Range (degree)
352
Tilting
Range (degree)
95
Network Interface
Ports
LAN - RJ-45
Supported Memory Cards
microSD Card
Screw kit, drill hole template, waterproof lid
UL, IC, RoHS, WEEE, REACH, IP65
Power Requirements
DC 12 V
Power adapter - external 6 Watt
Shipping Width
18.5 cm
Shipping Depth
20.5 cm
Shipping Height
19.7 cm
Shipping Weight
885 g
-30 °C
60 °C
Relative Humidity (operating)
