Introducing the EZVIZ W2D Wi-Fi Base Station
The EZVIZ Hub prolongs the battery life of the EZVIZ wire-free camera by up to 9 months. (Work Condition: Normal temperature and environment, triggered 5min/Day). The Hub Works with up to six EZVIZ wire-free Battery cameras
Furthermore, the Hub has a built-in 100db Siren so that when motion is detected you can choose via the EZVIZ app if you want an automatic or manual siren activation to occur.
A wide range of accessories are also available to enhance your wire-free Battery Camera experience, including a solar power panel, charging station, and metal mount for more secure installation.
Security has never been this easy
With a long-lasting 5,500 mAh rechargeable battery and 100% wire-free design, the standalone C3A can be placed anywhere you need it to go. With the help of the W2D, battery life lasts even longer. -
Hassle-free, effortless security
Use the C3A to monitor anywhere - whether indoors or out, or even in places without power outlets. Thanks to its wireless, battery powered and weatherproof design, the options are limitless! -
Watches over what matters most, day and night
The C3A lets you see wide-angle, Full HD images. Its night vision also ensures 24/7 protection even when it's dark outside. -
Two-way talk secures your home
Speak with visitors and hear what's happening anywhere and at any time using your smartphone. -
Extra protection with accurate detection
The C3A's passive infrared (PIR) motion detection feature sends you an instant alert with images and videos captured when a visitor approaches. Once you connect the C3A with the W2D, the W2D will even emit a 100-decibel siren when triggered, reminding you to check on what's happening.
- Hikvision CS-W2D-EUP Wire-Free Camera Base Station - gateway - 802.11b/g/n
- Product Type
- Gateway
- Environment
- Indoor
- Functions
- Extending wireless transmission range, charging
- Connectivity
- Wireless - 802.11b/g/n - 10/100 Ethernet
- Siren Sound Level
- 100 dB
- Frequency Band
- 433 MHz, 868 MHz, 915 MHz, 2.4 Ghz
- 9.5 cm x 9.5 cm x 11 cm
- Designed For
- EZVIZ C3A
- Product Type
- Gateway
- Environment
- Indoor
- Functions
- Connectivity Technology
- Wireless
- Frequency Band
- Siren Sound Level
- 100 dB
- LAN
- LED indicator
- Manufacturer
- Qualcomm
- Clock Speed
- 650 MHz
RAM
- Installed Size
- 128 MB
Flash Memory
- Installed Size
- 16 MB
- Nominal Voltage
- AC 120/230 V
- 10 Watt
- 9.5 cm
- 9.5 cm
- 11 cm
- 180 g
- Shipping Width
- 11.95 cm
- Shipping Depth
- 13 cm
- Shipping Height
- 21.5 cm
- Designed For
- EZVIZ C3A
