The C3W Pro, the upgraded color night vision camera from EZVIZ, is embedded with an AI algorithm to provide the person detection and more precise alerts even in darkness. You can also have two-way conversations with your family or visitors wherever you are using the EZVIZ App on your mobile phone. Peace of mind, always at your fingertips.
- EZVIZ C3W Pro - network surveillance camera
- Network surveillance camera - fixed - outdoor - dustproof / weatherproof
- Audio
- Yes: two-way audio capability
- 7.2 cm x 15 cm x 7.2 cm
- 395 g
- White
- Connectivity Technology
- Wired, wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 2560 x 1440
- Frame Rate (max)
- 30 frames per second
- Optical Sensor Type
- PS CMOS - 1/2.7" - 4 MP
- Minimum Illumination
- 0.01 lux F1.6 - AGC on , 0 lux - IR
- Focal Length Control
- Fixed focal
- Focal Length
- 2.8 mm
- Lens Mounting
- M12 mount
- Lens Iris
- F/1.6
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Ethernet 10Base-T/100Base-TX
- Voltage
- DC 12 V
- Digital Wide Dynamic Range (D-WDR), 3D Digital Noise Reduction Technology, self-adaptive shutter, anti-flicker, dual video stream, heartbeat, password protection, watermark, 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA2-PSK, WPA-PSK
- Environmental Parameters (operating)
- -30 °C - 60 °C; 0 - 95% (non-condensing) relative humidity
- Audio Support
- Wired, wireless
- 7.2 cm
- 15 cm
- 7.2 cm
- 395 g
Camera
- Colour - Day&Night - fixed - outdoor - dustproof / weatherproof
- Digital Video Format
- H.265, H.264
- Max Digital Video Resolution
- 2560 x 1440
- Infrared LEDs
- Infrared Distance
- 30 m
- Frame Rate (max)
Image Sensor
- 4 MP PS CMOS 1/2.7"
Lens Construction
- M12 mount - fixed focal
- Focal Length
- 2.8 mm
- Lens Iris
- F/1.6
- Horizontal Field of View (degree)
- 100
- Diagonal Field of View (degree)
- 121
- Network Interface
- Ports
- LAN - RJ-45
- Supported Memory Cards
- microSD Card
- Included Accessories
- Waterproof connectors, screw kit, mounting template
- IP67, UL, WEEE, FCC, REACH, RoHS
- White
- Power Requirements
- DC 12 V
- Power Device
- Power adapter - external 6 Watt
- Shipping Width
- 25.2 cm
- Shipping Depth
- 11 cm
- Shipping Height
- 9.2 cm
- -30 °C
- 60 °C
- Relative Humidity (operating)
- 0 - 95% (non-condensing)
