Ezviz Full HD Indoor Smart Security PT Cam with Motion Tracking
Quicklinx: H0RYWS00 Mfr#: CS-C6N-B0-1G2WF
Smart Wi-Fi Pan & Tilt Camera
The C6N from EZVIZ comes equipped with a Smart IR function, which uses advanced infrared (IR) lighting to capture more details in dim light. With its 360-degree field of view and smart tracking function, you won’t need to worry about missing a thing.
Smart night vision with Smart IR
With Smart IR, the intensity of the infrared LEDs automatically adjusts to prevent overexposure in night vision mode, so you will get more details of the object or person captured at night.
Zero blind spots
Keep tabs on every corner with just one C6N. Its expansive 360-degree field-of-view ensures full coverage, so you don’t miss a thing.
Smart tracking
When it detects a moving object, the C6N is smart enough to automatically track its motion while alerting you with an image in real-time.
Communication anytime
Talk to your loved ones and deter unwelcome strangers – all by using the C6N’s two-way communication feature. Using the EZVIZ App on your mobile device, you can easily and conveniently enjoy communication wherever you might be.
Multiple Storage Solutions
Want a bit more privacy? With one tap of the
Save your recordings with flexible and secured solutions. The C6N comes with a built-in MicroSD card slot that can store up to 256 GB of recorded footage. You can also save your images to EZVIZ Cloud* for additional back-up.
*Cloud storage service is only available in certain markets. Please verify the availability before making any purchase
EZVIZ C6N - network surveillance camera
Network surveillance camera
Wireless
Camera
Colour - Day&Night
Motion Detection
Wireless
Camera
Colour - Day&Night
Motion Detection
