Ezviz Full HD Indoor Smart Security Cam - 4MP H.265
Quicklinx: H0RZWS00 Mfr#: CS-C6N-D0-8B4WF
  • microSDHC Card
  • microSD Card
The C6N from EZVIZ comes equipped with a Smart IR function, which uses advanced infrared (IR) lighting to capture more details in dim light. With its 360-degree field of view and smart tracking function, you won't need to worry about missing a thing.
  • Smart night vision with Smart IR
    With Smart IR, the intensity of the infrared LEDs automatically adjusts to prevent overexposure in night vision mode, so you will get more details of the object or person captured at night.
  • Zero blind spots
    Keep tabs on every corner with just one C6N. Its expansive 360-degree field-of-view ensures full coverage, so you don't miss a thing.
  • Smart tracking
    When it detects a moving object, the C6N is smart enough to automatically track its motion while alerting you with an image in real-time.
  • Communication anytime
    Talk to your loved ones and deter unwelcome strangers - all by using the C6N's two-way communication feature. Using the EZVIZ App on your mobile device, you can easily and conveniently enjoy communication wherever you might be.
  • Protects your privacy
    Want a bit more privacy? With one tap of the EZVIZ App on your mobile device, you can enable C6N's sleep mode, giving you privacy when you need it.
EZVIZ C6N 4MP - network surveillance camera
Network surveillance camera - pan / tilt
Audio
Yes: two-way audio capability, built-in microphone, built-in speaker
8.8 cm x 8.82 cm x 11.9 cm
252 g
Wireless, wired
Camera
Colour - Day&Night
Max Resolution
2560 x 1440
Frame Rate (max)
20 frames per second
Motion Detection
Video Modes
1080p
Optical Sensor Type
PS CMOS - 1/3" - 4 MP
Focal Length Control
Fixed focal
Focal Length
4 mm
Lens Mounting
M12 mount
Lens Iris
F/2.4
Panning Range (degree)
350
Tilting Range (degree)
55
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Ethernet 10Base-T/100Base-TX
Voltage
DC 5 V
Smart IR, smart tracking, Smartphone Monitoring, cloud recording, instant notification, self-adaptive shutter, infrared cut filter, 3D digital noise reduction (DNR), Digital Wide Dynamic Range (D-WDR), Adaptive Bitrate (ABR), 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA2-PSK, WPA-PSK, progressive scanning, reset button
Environmental Parameters (operating)
-10 °C - 45 °C; 0 - 95% (non-condensing) relative humidity
Audio Support
Wireless, wired
8.8 cm
8.82 cm
11.9 cm
252 g
Camera
Colour - Day&Night - pan / tilt
Digital Video Format
H.264
Max Digital Video Resolution
2560 x 1440
Motion Detection
Video Modes
1080p
Digital Zoom
4
Infrared LEDs
Infrared Distance
10 m
Digital Video Capture Resolution
2560 x 1440
Frame Rate (max)
Image Sensor
4 MP PS CMOS 1/3"
Lens Construction
M12 mount - fixed focal
Focal Length
4 mm
Lens Iris
F/2.4
Horizontal Field of View (degree)
85
Vertical Field of View (degree)
55
Diagonal Field of View (degree)
124
Panning
Range (degree)
350
Tilting
Range (degree)
55
Network Interface
Ports
LAN - RJ-45
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
Camera mount base, screw kit, drill hole template
FCC, UL, WEEE, REACH, RoHS
Power Requirements
DC 5 V - 2 A
Power adapter - external 5 Watt
Shipping Width
10.3 cm
Shipping Depth
10.3 cm
Shipping Height
16.8 cm
-10 °C
45 °C
Relative Humidity (operating)
