Ezviz eLife BC1C Battery-Powered Camera
Quicklinx: H0VSWS00 Mfr#: CS-BC1C-A0-2C4WPBDL
Hassle-free home protection supported by extended battery life.
The BC1C is a 100% wire-free rechargeable camera that delivers well-rounded home protection for up to 210 days on one single charge. It can be simply installed anywhere for enhanced security, inheriting EZVIZ's core technologies of color night vision, two-way talk, active defense and more.
Long-lasting battery life for extended peace-of-mind.
Equipped with a 7,800 mAh rechargeable battery, the BC1C can last for up to 210 days* on one full battery charge, ensuring stable performance all day and night. It can also be connected to EZVIZ Solar Panel to get powered directly.
*Data from EZVIZ Lab’s test results, based on the usage of 5 minutes per day, including the activities of camera detection and auto-triggered recording. Actual use may vary due to environmental factors and the frequency of camera activities
Vivid night vision.
Thanks to two built-in spotlights, the BC1C can render vivid color imaging even in pitch-black darkness. This allows you to see crucial details that would otherwise be lost.
Motion alerts are more accurate than ever.
Integrating a PIR sensor and the person-shape detection algorithm, the BC1C camera is intelligent enough to distinguish persons from other moving objects, keeping you safe while also reducing unwanted notifications.
A vigilant guard over your property.
Users can set specific time frames for detection. Once the camera detects a person-shape, the BC1C will automatically set off a siren and flash two spotlights* to let them know they have been detected.
Customizable voice messages.
A thoughtful product by design, the BC1C allows you to create unique voice messages* for greeting or deterrence.
*Supports recording three 10-second audio messages
Talk as if you were there.
See and hear what’s going on and chat with your visitors—all with a tap on the EZVIZ App!
Fast and easy wire-free setup.
Featuring a large battery, Wi-Fi connectivity, and a magnetic base, the BC1C camera requires exactly zero professional help in installation. Simply attach the camera to any metallic surface and it is good to go!
Built to last.
The BC1C camera features an IP66 enclosure, offering high levels of protection against dust and water and delivering long-lasting protection in even the toughest weather conditions.
  • Sharper details with 2K+ resolution
    Every detail is clearer than 1080p resolution. The picture can be clearly displayed on the EZVIZ app even after being magnified 8 times.
  • Vivid night vision
    With two built-in spotlights and 2K+ resolution, EZVIZ eLife 2K+ can paint colorful images even in pitch-dark darkness. This allows you to see crucial details that would otherwise be lost.
  • Long-lasting battery life
    Equipped with a 10400 mAh rechargeable battery, the camera can last for up to 270 days on one full battery charge, ensuring stable performance all day and night.
  • Motion alerts are more accurate than ever
    EZVIZ eLife 2K+ integrates a PIR sensor and a human shape detection algorithm, which is smart enough to distinguish people from other moving objects, ensuring your safety, and reducing unnecessary notifications.
  • Customizable voice messages
    A thoughtful product by design, the EZVIZ eLife 2K+ allows you to create unique voice messages for greeting or deterrence.
  • Built to last
    The EZVIZ eLife 2K+ camera features an IP66 enclosure, offering high levels of protection against dust and water and delivering long- lasting protection in even the toughest weather conditions.
EZVIZ eLife BC1C - network surveillance camera - bullet
Network surveillance camera - fixed - bullet - dustproof / waterproof
Audio
Yes: two-way audio capability, built-in speaker
Camera Mount Type
Surface mount, wall mount
6.28 cm x 10.476 cm x 6.28 cm
365 g
Wireless
Camera
Colour - Day&Night
Max Resolution
2560 x 1440
Frame Rate (max)
15 frames per second
Motion Detection
Video Modes
2K+
Optical Sensor Type
PS CMOS - 1/2.8" - 4 MP
Minimum Illumination
0.01 lux F1.6 - AGC on , 0 lux - IR
Focal Length Control
Fixed focal
Focal Length
2.8 mm
Lens Mounting
M12 mount
Lens Iris
F/1.6
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Intelligent Assistant
Alexa, Google Assistant
Voltage
DC 5 V
Colour Night Vision, Voice Alert, reset button, Dual LED Spotlights, Active Defense, Smart Motion Detection, 3D Digital Noise Reduction Technology, infrared cut filter, 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA2-PSK, WPA-PSK, anti-flicker, heartbeat, password protection, cloud recording
1-year warranty
Environmental Parameters (operating)
-20 °C - 50 °C; 0 - 95% (non-condensing) relative humidity
Audio Support
Bullet
Camera Mount Type
Wireless
6.28 cm
10.476 cm
6.28 cm
365 g
Camera
Colour - Day&Night - fixed - dustproof / waterproof
Digital Video Format
H.265, H.264
Max Digital Video Resolution
2560 x 1440
Motion Detection
Video Modes
2K+
Infrared LEDs
Infrared Distance
10 m
Digital Video Capture Resolution
2560 x 1440
Frame Rate (max)
Flash Memory
32 GB
Image Sensor
4 MP PS CMOS 1/2.8"
Lens Construction
M12 mount - fixed focal
Focal Length
2.8 mm
Lens Iris
F/1.6
Horizontal Field of View (degree)
100
Vertical Field of View (degree)
52
Diagonal Field of View (degree)
116
Network Interface
Magnetic base, mounting bracket, screw base, drill hole template, screws
IP66, FCC, WEEE, RoHS, REACH, UL
Power Requirements
DC 5 V - 2 A
Power adapter - external 5 Watt
10400 mAh
Internet of Things (IoT)
Limited warranty - 1 year
Shipping Width
18.6 cm
Shipping Depth
10.3 cm
Shipping Height
10.3 cm
Shipping Weight
835 g
-20 °C
50 °C
Relative Humidity (operating)
