Ezviz DB1C Video Doorbell Kit inc Chime and Transformer Kit
Quicklinx: H0W0WS00 Mfr#: CS-BD-DB1C
Enjoy high-quality video chat with visitors and keep an eye on what's happening at your front door right through your phone. The DB1C is a powerful video doorbell with built-in artificial intelligence capability.
  • See every detail you need to see
    The DB1C delivers 1080p video, bringing the rich precision and extraordinary images you would expect from EZVIZ.
  • Person-detection enabled
    With its AI algorithm onboard, the DB1C intelligently detects a person's movement, ensuring that you only receive notifications when people move by. You can turn off this function if you need other motion alerts such as those triggered by animals or cars.
  • Covers every inch, from head to toe
    Featuring a 170-degree vertical view, the DB1C reliably records everything you need to see. Even a package on the ground will be clearly captured.
  • Two-way talk
    When the EZVIZ App notifies you of a visitor at the front door, you can see and talk to the person right away, and from wherever you are.
  • Dual-band Wi-Fi connectivity
    Not all video doorbells support dual-band connectivity. The DB1C does, and it gives you the flexibility to choose between 2.4 or 5GHz connections for optimal performance on your network.
  • Save money on storage and bandwidth
    The DB1C doorbell features the advanced H.265 video compression technology, achieving better video quality with only half the bandwidth and half the storage space of the older H.264 video compression standard.
  • Fearless in any weather
    Rated with IP65 protection, the DB1C doorbell works reliably in rain, sleet, or snow, bringing you peace of mind throughout the year.
  • Multiple storage solutions
    With multiple storage options, you can choose where to save your recordings. The DB1C can even save to all three locations at the same time for added backup in case the camera is damaged, or your network crashes.
  • Security at your fingertips
    With the EZVIZ App, you can capture, save, protect, and share what's valuable to you.
EZVIZ DB1C - IP intercom station - 802.11a/b/g/n - with chime transformer
IP intercom station
Functions
Motion detection, camera
Integrated Components
Microphone, speaker
Bundled with
Chime transformer
Wireless - 802.11a/b/g/n
Frequency Band
2.4 Ghz, 5 GHz
Camera
CMOS 1/2.4" - Max Resolution 1536 x 1536 - audio - Day&Night
4.63 cm x 1.93 cm x 12.83 cm
IP intercom station
Functions
Microphone, speaker
Bundled with
Chime transformer
Wireless - IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 Ghz, 5 GHz
Waterproof, dustproof, reset button, H.264 streaming video, 2-way audio, video intercom, microSD/SDHC/SDXC Memory Card slot, H.265 streaming video
Camera
Image Sensor
CMOS - 1/2.4"
Lens Aperture
F/2.4
Focal Length
2.1 mm
Day & Night Functionality
Audio Support
Max Digital Video Resolution
1536 x 1536
Infrared cut filter, Digital Wide Dynamic Range (D-WDR), 2-way voice communication, 3D digital noise reduction (DNR), up to 5m night vision distance, 170° field of view (vertical)
Mounting plates, power kit, screwdriver, mounting screws
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
Nominal Voltage
AC 12 - 24 V
Warranty
UL, FCC, RoHS, WEEE, REACH, IP65
4.63 cm
1.93 cm
12.83 cm
102 g
Shipping Width
10.2 cm
Shipping Depth
9.7 cm
Shipping Height
17.25 cm
-30 °C
60 °C
0 - 95% (non-condensing)
