Ezviz C6 Pan and Tilt Wi-fi Camera
Quicklinx: H0S0WS00 Mfr#: CS-C6-A0-8C4WF
  • microSD Card
A camera small in size, but big on functionality. With on-camera AI, the C6 2K? identifies humans and pets in an instant, and detects abnormal sounds to add an extra layer of protection. Its impressive video and audio quality delivers leading performance. Enhance your home and be there for your loved ones with the joy and confidence that the C6 offers.
  • Impressive video quality in 2K?
    The C6 camera excels at seeing everything clearly and vividly. It renders every detail in sharp 2K? resolution, effectively reduces image overexposures, and provides color imaging in extremely low-light conditions.
  • Smart enough to detect, zoom, and follow
    The camera can automatically zoom in up to four times to follow a moving object so you see details and get the whole picture at the same time. You can always enable the AI option to detect and track specifically human movements.
  • Know how your furry friends spend their day
    Away at work but do not want to miss an "aww" moment? You can receive mobile notifications whenever your pet is detected by the camera. Even when they are jumping and running, the C6 captures them clearly.
  • Notifies you when you're needed
    The camera alerts you if the noise level suddenly changes - whether your baby cries or a siren breaks out. Your family members can also simply wave at the camera to initiate a video call to your phone.
  • Surprisingly good audio experience
    Communications are the basis of companionship, so EZVIZ made the audio quality better than you'd expect.
  • Steady connection for boosted performance
    Set up the camera network, either wired or wirelessly. You can connect the camera to either 2.4 or 5 GHz band to ensure a strong Wi-Fi signal.
EZVIZ C6 - network surveillance camera
Network surveillance camera - pan / tilt
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
10 cm x 10 cm x 9.65 cm
325 g
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
2560 x 1440
Motion Detection
Video Modes
2K
Optical Sensor Type
CMOS - 1/3"
Minimum Illumination
0.1 lux - colour - F1.6 - AGC on , 0 lux - IR
Focal Length Control
Fixed focal
Focal Length
4 mm
Lens Mounting
M12 mount
Panning Range (degree)
353
Tilting Range (degree)
133
Ethernet 10Base-T/100Base-TX, IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Voltage
DC 5 V
Backlight Compensation (BLC), progressive scanning, saturation control, brightness control, contrast control, image mirror, 3D digital noise reduction (DNR), Digital Wide Dynamic Range (D-WDR), WPA, WPA2-PSK, 64-bit WEP, 128-bit WEP, WPA-PSK, WPA2, watermark, Auto-Zoom Tracking, Person Detection
1-year warranty
Environmental Parameters (operating)
-30 °C - 60 °C; 0 - 95% (non-condensing) relative humidity
Audio Support
Wired, wireless
10 cm
10 cm
9.65 cm
325 g
Camera
Colour - Day&Night - pan / tilt
Digital Video Format
H.264, H.265
Max Digital Video Resolution
2560 x 1440
Motion Detection
Video Modes
2K
Infrared LEDs
Infrared Distance
10 m
Image Sensor
CMOS 1/3"
Lens Construction
M12 mount - fixed focal
Focal Length
4 mm
Horizontal Field of View (degree)
79
Vertical Field of View (degree)
42
Diagonal Field of View (degree)
92
Panning
Range (degree)
353
Tilting
Range (degree)
133
Network Interface
Ports
LAN - RJ-45
Supported Memory Cards
microSD Card
Camera mount base, screw kit, drill hole template
UL, NOM, IC, FCC, RoHS, WEEE, REACH
Power Requirements
DC 5 V
Power adapter - external 8 Watt
Limited warranty - 1 year
Shipping Width
11.6 cm
Shipping Depth
11.6 cm
Shipping Height
16.4 cm
Shipping Weight
641 g
-30 °C
60 °C
Relative Humidity (operating)
